Replaced the tubes in my 1998 Lopi Endeavor
madrone
1,290
Just South of Portland, OR
For the first time. They looked a little saggy, and were flaking like crazy. Plus, I had lost most of the original retaining pins. $68 at the local shop.
Thing is, after I pulled the old tubes out, it looks like they could easily go another 5 years. I considered putting them back in, but the hole diameters are different on the new ones, so I thought I'd see if it burned any different. Will post my findings.
[Hearth.com] Replaced the tubes in my 1998 Lopi Endeavor
I am not certain of this, but the new ones are stainless steel. I have read the older ones were not stainless and did not last as long. So if the last tubes lasted since 98 and could go longer...
I think they mightbe stainless. I have a liberty purchased in February 1997 and I have replaced everything but the tubes. All other components are regular common structural steel, which burn out in 3-4 years.
Craig
New ones are definitely stainless, and I'm guessing the old ones were as well.
As for the performance of the new tubes, there's a noticeable difference. I'm shutting the primary down farther than previously. The distance between holes and number of holes is the same, but the new tubes have larger diameter holes.
Still haven't replaced the gasket.
