Running a Harman Wood Pellet Stove on Low Heat?
Don2222
9,117
Salem NH
On a Harman - What is Low Heat?
Is this the only stove where the top and sides get hot enough to burn your fingers?
I am testing out this Harman P61 now a P61a
Pics and detail on my stove. > https://www.hearth.com/talk/threads/my-first-harman-what-color-is-it.108227/page-2#post-1439004
After startup I set the controls to the recommended settngs.
Temperature control to 78 Deg F
Feeder Rate knob on 4
Mode to Room Temperature between L and H
The room temp probe is plugged in but coiled up and not hanging down which maybe a big mistake?
Wow the heat gun at 12 inches away was reading 515 Deg F !!! This is great heat!
It was also sucking down the wood pellets.
I just tried these settings shown in pics below:
Temperature control to 72.5 Deg F
Feeder Rate knob on 2
Mode to Room Temperature on L
Now at 6 inches away I am reading 347.9 Deg F.
Pics below are at the above settings.
I did notice on these settings the fire is much closer to the auger and there is more ash on the edge of the burn pot.
I am burning CUBEX ! LOL I know they are Hot Pellets but I got 15 bags at $2 each bag!
Feeder Rate knob on 3
Then I uncoiled the room temp probe. The room temp probe started working and shut the stove down. LOL
Also the 1st time I tried to start the stove, I did not have any flue vent connected. It did not start! LOL
My question is:
How do I turn the heat down? What is the best way?
See pics below
Click to Enlarge:
My question is:
See pics below
Click to Enlarge:
Turn the heat down with the temperature knob. The Hi-Lo knob only controls the distribution blower speed. Your feed rate is probably right where it should be. Mine are always set for 3 - 3.5
Reactions: gbreda
Thanks DAKSY
I may put a T-Stat on one leg of the room probe and set the temperature knob to 90. Then I can control the temperature with the T-stat.
In the meantime I will do what you said.
Thanks again.
