Sears Craftsman LT-1000 Carburetor Bowl leak around the solenoid!! What a gas smell!!
Don2222
9,264
Salem NH
Hello
It looks like a gas leak where the solenoid
I removed the carburetor and checked the solenoid. See video.
It seems to be working fine
Is there a good sealant that works with gasoline around the threads?
What is the best fix? See pics
I also heard that the solenoid really not needed and it can be disabled by cutting the stem off and disconnecting the wire? Anyone do that?
[Hearth.com] Sears Craftsman LT-1000 Carburetor Bowl leak around the solenoid!! What a gas smell!! [Hearth.com] Sears Craftsman LT-1000 Carburetor Bowl leak around the solenoid!! What a gas smell!! [Hearth.com] Sears Craftsman LT-1000 Carburetor Bowl leak around the solenoid!! What a gas smell!!
Just fix it. Verify it’s not just loose and if so, tighten it. Next, remove it and if it’s not a gasket, reseal the threads with any of the pipe dopes that are rated for gasoline.
Thanks, I found some dope good for oil so I will try that.
Sol. is a fuel shut off device. Keeps your crankcase from filling up with gas if float sticks and during transport.
Reactions: Don2222
  • [Hearth.com] Sears Craftsman LT-1000 Carburetor Bowl leak around the solenoid!! What a gas smell!!
Reactions: Highbeam
I added one to my Weber carb to stop dieseling. You know, running after you shut the key off.
