Sears Craftsman LT-1000 Carburetor Bowl leak around the solenoid!! What a gas smell!!
Don2222
9,118
Salem NH
Hello
It looks like a gas leak where the solenoid
I removed the carburetor and checked the solenoid. See video.
It seems to be working fine
Is there a good sealant that works with gasoline around the threads?
What is the best fix? See pics
I also heard that the solenoid really not needed and it can be disabled by cutting the stem off and disconnecting the wire? Anyone do that?
DD61DBDB-14DE-4EAC-B258-9820D12E2167.jpeg D3065B37-CDB1-4FFF-91AD-2D3E7DD3851F.jpeg 1ECC3DB4-613C-465F-BE47-38881BE214E7.jpeg
Just fix it. Verify it’s not just loose and if so, tighten it. Next, remove it and if it’s not a gasket, reseal the threads with any of the pipe dopes that are rated for gasoline.
Thanks, I found some dope good for oil so I will try that.
Sol. is a fuel shut off device. Keeps your crankcase from filling up with gas if float sticks and during transport.
Reactions: Don2222
Reactions: Highbeam
I added one to my Weber carb to stop dieseling. You know, running after you shut the key off.
