Its 30 degrees outside, I have a central boiler classic edge that has run without problems the past three years. We just fired up the boiler and th shop thermostat is set at 52 yet the shop is currently warmed to 68 degrees. The Pump inside the shop is on but isn't running so the thermostat must be working. Could the thermostatic valve be allowing hot water to run straight through the mixing valve and through the pump heating the floor? SD Viking
