S
ScotO
Guest
Again, proof that top-covering the stacks works with great success!!Very!
When you are limited on space, Sparky, you gotta do what you gotta do. Does wood stacked in single rows season faster? I'm sure it does. Does top covering help in making a cube of wood faster? I'm sure it does. The OP in this thread asked if his stack of wood will season the way it was stacked. We who stack in big blocks simply are stating that if he has a couple of years, and if he top-covers his wood, that yes it absolutely WILL season.....not in 6 months or even a year, but it WILL season that way. How is that deceiving anyone? We answered the original question.Well scotty, the moisture coming out of the middle of the stack is even MORE restricted by the top covering, you did see some of the posts by people that stated stacking tight did not work for them that well. I dont think its a good idea to tell people how long it takes to dry your wood when you stack it in that manner, just dont take as long when you stack single rows and how you get away from some rot is beyond me.
Sparky, its only cross stacked on the ends and periodically every 8-10' or so......most of my stack is stacked just as the OP's. The cross-stacking adds stability to the ends and throughout the stack.Scotty, is that your wood pile cross stacked, you are aware that is goona be better then how the OP has his stacked.
![[Hearth.com] Should I Cover The Cube? [Hearth.com] Should I Cover The Cube?](https://www.hearth.com/talk/data/attachments/106/106708-f1ccc40abc0b8abb9ace96ef3d65a3d9.jpg?hash=m8jX6tLoW4)
![[Hearth.com] Should I Cover The Cube? [Hearth.com] Should I Cover The Cube?](https://www.hearth.com/talk/data/attachments/106/106709-6f08b54c65992f404e00b7ca746e1a1c.jpg?hash=rseLvm53-a)
![[Hearth.com] Should I Cover The Cube? [Hearth.com] Should I Cover The Cube?](https://www.hearth.com/talk/data/attachments/106/106710-3dcabb6cfb4943bf3340b3637d0fc6b1.jpg?hash=TmT2iPrdbj)
![[Hearth.com] Should I Cover The Cube? [Hearth.com] Should I Cover The Cube?](https://www.hearth.com/talk/data/attachments/106/106711-7a40492d454674ac21f4fc42f9f2a7d5.jpg?hash=VWfkhCzueL)
![[Hearth.com] Should I Cover The Cube? [Hearth.com] Should I Cover The Cube?](https://www.hearth.com/talk/data/attachments/106/106714-f4975ef2f2e94f0f1d40a87a57e0f0ed.jpg?hash=OsuEYELURf)
![[Hearth.com] Should I Cover The Cube? [Hearth.com] Should I Cover The Cube?](https://www.hearth.com/talk/data/attachments/106/106715-583ad452ffe163f7bbb6fac590fbb32a.jpg?hash=n-um_bcHxW)
How many of those who've had problems had the wood top-covered? I'm betting that they didn't have it properly top-covered. That is the big factor in a large stack of wood.....top-covering it.Have you been reading the posts on here scotty for the last few years about drying wood? And there is a chance of rot with a wood pile like that, and are you reading the number of posts who stated they had problems with wood stacked that way? Best advice more air circulation.
Why do you think there is a fair amout of people claim wood rots, I am guessing in part to poor stacking practices.
I do make some big stacks and leave them open until the end of fall then top cover those I won't use for the winter. The stacks or piles that get used get covered in full with a 2*4 to help keep the tarp straight and on for the winter. Leaving it exposed as much as possible is the best thing you can do.How many of those who've had problems had the wood top-covered? I'm betting that they didn't have it properly top-covered. That is the big factor in a large stack of wood.....top-covering it.
Yes Pete, that's pretty much what I do. The first two years of being C/S/S, the wood gets no top cover......in the summer of the third year (before the wood is to be burned), I top-cover only the 3 year wood. However, I will probably top-cover all of it come late August......next year, it will all be put in my woodshed.I do make some big stacks and leave them open until the end of fall then top cover those I won't use for the winter. The stacks or piles that get used get covered in full with a 2*4 to help keep the tarp straight and on for the winter. Leaving it exposed as much as possible is the best thing you can do.
Pete
Well you can stack your wood any way you want to but you will not find any article any where that recomends stacking wood in that manner and in over 30 years of wood burning I have never had a problem with sizzling wood and have always stacked in single rows and in some cases burnt the wood that has cured over one long summer. I have been told (on this forum) I can not dry wood that quick but many factors to consider, not sure how many can make claims on how long it takes to dry wood and they dont stack in the best way possible.I guess I'll find out a few years from now. Hopefully it works out.
I have a four row wide pile that gets good sun and is not covered and it looks real dry.
I had another pallet wide pile that was covered that just I put in the garage for the winter that had some wetness to it; I think it might be because I hadn't tended to the cover for a long long time (ignored it)....I think it gathered and funneled water down in several places.
So, if you go for long term top cover, you have to maintain the cover.
I'm leaning towards not covering if in sun. But this cube thing new to me, and I hope to keep the rain out of the middle.
Of course, there WILL be shrinkage, so who knows if the thing will hold together, cover and all, for 3 years.
I agree with you, the direct ground contact isn't good (I mentioned that in one of my earlier posts on this thread). That is the hinge factor for me.Agree completely.
However, if the large stack is sitting directly on the ground, and up against/under trees, it will not get the air movement that is needed to get the moisture out of the middle. And there is no way the bottom layer will dry out - it will just gradually decompose into the ground.
Are you just now figuring that out??I see we are beating a dead horse.
https://www.hearth.com/talk/threads/how-many-years-to-dry-when-stacked-in-wood-cube.110340/
There is a lot of things done by many many menbers on here that I want no part of.Are you just now figuring that out??
Bottom line is, wood stacked led in single rows will season faster, but when you got to maximize your space sometimes you gotta cube it. And when you cube it, if done correctly, it WILL season. Not as fast, and you gotta top cover it for a while (and get it off the ground), but it CAN and HAS been done by many, many members on here......
That post was from June 2, just when I had started splitting.I see we are beating a dead horse.
So Scotty I have a question for you, and I am being serious, why do some of the very same people who stack in multiple rows give advice about the wood being stacked too tight for air flow, ran into some posts while doing a search. Both methods will reduce air flow to an extent.
"Stack your wood loose enough to let a mouse through but not enough for a cat to chase it"
out in single rows in your yard... You do what you have to and make it fit. With 20+ cords C/S/S on hand you are certainly not in a hurry to burn that wood! So again, like Scotty said, get it off the ground and top covered and let it sit! It will be ready when you need it.We use essential cookies to make this site work, and optional cookies to enhance your experience.
