It is some thick stuff, but if you take the 1" air gap and the material into factor it evens out. I got a small sample block of it, what do you guys want seen done to it? Blowtorch? 12ga? Small tile?
The hearth shop i work at recently purchased this stuff to start using. We tried putting stone on it with type S mortar and after 3 days you could easily pull the stones off. We wet the skamotec and scratch coated it, but it still dried insanely fast making it hard to even scratch coat. I would guess your first answer would be more water. But i can hardly see using buckets of water in someones living room with carpet and hard wood and all. Any other suggestions ? The idea of this stuff sounds great and even the faster drying scratch coat is a plus. It just doesnt seem to be working. Should we be using thin set to scratch coat it for stone ??
Now that it is nice outside I can try the blowtorch test and not have to worry about getting yelled at. I might have some small tile sitting around from the kitchen remodel that I can try adhering to the board.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
