- Oct 3, 2007
- 1,539
I'm thinking of doing a small (12' x 16') pole building next spring to serve as a place for outdoor tools, firewood, etc... I want to go with pole construction because I want a gravel floor and it will be faster/cheaper to build. When I look for guidance on the 'net about basic pole building construction I find plans for huge (20' x 40' with 10' ceilings and massive roof trusses) buildings. It's easy enough to scale the designs down, but I'm wondering if I can scale the materials down a bit. For example, the poles themselves. The large pole buildings call for at least 6x6 if not 8x8 posts. Since my roof will be a simple gable with a 12' span, I'm wondering if 4x4 posts would be sufficient. 4x4x12 posts (4' in the ground, 8' above ground)-I was planning to dig holes 12" in diameter and 48" deep on 4' centers for the long walls and 6' centers for the short walls. The bottom 6" of the hole would be filled with concrete. The posts will rest on the concrete and the holes will be filled with gravel. The difference between using 4x4 posts and 6x6 posts (11 posts total) is just shy of $200. Some may say "just go with the larger posts and be done with with it-its only $200," but if using 6x6 posts is complete overkill for a building that small, why spend the extra money? I should probably add that snow load is a variable because I am in Northwestern New Jersey at the median elevation (500') for the area. Feet of snow is an increasingly rare phenomenon, but it's not uncommon to get 8-10" of heavy wet stuff in late February/early March. Any ideas?
