So got a quote of $3,480 for the pedestal and ashpan on the sirocco 30.2, sound right?
This may be the case, but check the clearances. Memory seems to tell me that the BK 30 boxes don't take up much more space than the BK 20 boxes, after all clearances are considered.A large stove and hearth will also take up a lot of space in a smaller home, maybe the Sirroco 20 would be a better fit? I'm going with a Jotul 602 corner install in my 600 sqft cabin mainly to save space but also like the looks, price and reputation as a great heater.
When burning that low are smoldering does it smoke the glass up?Nope. That's the whole point of a cat stove. You can run the stove dead-cold, just smouldering the wood and producing wood gas. The combustor can stay "lit" or "active" at less than half the temperature of a non-cat, consuming (re-burning) the wood gas, and keeping your flue clean.
Most flue accumulation in a cat stove happens during the initial start-up phase, when you have the combustor bypassed, and ironically you're burning on the highest setting then.
Yes. The inside of a BK firebox run on low is a black ugly mess, but as long as you keep your catalytic combustor in the active region, the pipe will stay as clean as if you were running on any other setting. It takes dry wood and reasonably-optimal draft to run at the absolute lowest settings, but in general, cat stoves can run much lower than tube stoves. We also generally run the first 20 - 30 minutes of each load on high, to regularly burn off the build-up that can occcur when shouldering a single load for 30+ hours, it’s really not much of an issue.When burning that low are smoldering does it smoke the glass up?
It only needs ember protection. Any non-combustible surface will work. This could be tile, brick, concrete, or a sheet of metal.
I like the glass idea! We have hand scraped distressed bamboo floors. I'll talk to the local glass shop and see what they have. Never thought glass would support 4~500 pounds.
I feel like some kind of levelers or shims will be necessary for proper fit.The glass is not supporting the weight. The floor is. Like if you put a newspaper on the ground and drive your truck over it. The newspaper isn’t supporting the weight, the ground is.
glass is flat and effectively a rigid solid. That is the challenge. If the floor under the glass is not flat or if it yields under the weight of the stove then the glass could crack.
Glass hearth pads look cool. Almost invisible. Nice to bevel the edges a bit so that you don’t catch your toe on it!
