mooney said:SmokeyTheBear said:tchdngrnby said:Just my two cents, the operators manual does not give that average user enough information to properly clean this stove.
That is true for most of the manuals I've seen.
In two words, they stink.
When my stove was installed they showed me how to clean the stove according to the manual.
I laughed and said Ok, where are the ash traps hidden?
Meanwhile mooney is getting an education in all of the places to look for his problem.
mooney, when you replaced your door gasket did you do the dollar bill test in several places around the door. I hate to say this but more than one person has replaced their gaskets only to discover that:
1: They stretched it so that it can't seal correctly.
2: It really wasn't the gasket that was the problem, but the door hinges loosening up or the latch no longer engaging.
3: They bought an incorrect replacement size.
With gaskets, looks can be deceiving.
I totally agree... I didn't do the dollar bill test, please explain. I did replace the gasket with a 5/8" rope that I was careful not to stretch. I'm pretty sure it needed replacing anyways as where the two ends of the rope came together was fraying and if it wasn't already leaking air, it would have been shortly.
And yes, I think the manual sucks. ;-)
I was trying to be nice and not use that s word.
With the stove off and cold
Place a dollar bill in the door and close it so the dollar bill is between the door gasket and the stove.
Then pull the dollar bill out it should offer quite a bit of resistance, as in being very difficult to move if at all.
Do this test in at least two spots on each side of the door.
If the test fails in any spot you need to revisit the gasket/door hinge/latch situation as you have an air leak.
