Yes I did it the other day. Same day that I pulled the stove away fron the fireplace. I was amazed to see how little ash was in the secondary burn chamber! The cat had small parts that had cracked away. Not too many though. The overnight burn from the night before was as good as usual. The furniture pads are still under it BTW!raybonz said:VCBurner said:Not a good overnight burn last night. I can't blame the stove. The wood, which was cherry and oak, is not as dry as it should be and I stuffed a huge oak split in there. It was 67 in the house at 6am, three or four fresh splits went in at 10pm. The bed of coals were not as big when i put in the coals, either. I was trying to tone down heat rpoduction last night because it was 78 in here at 7pm. I won't do that again. Boy, would I love a new cat!!
Chris have you tried vacuum cleaning your cat and inspect that the holes are not blocked? There is also a cleaning procedure you can try :
(broken link removed to http://www.condar.com/combustorcleaningmanual.pdf)
Ray
Oh! Good news is...I loaded her up at 6am (this morning,) the house was at 67...four hours later house is at 77 and she's still going strong!! Stove temp is slightly over 400, but the cat is at 500. So, yeah, I need a new cat, badly. I looked into ordering one and found a couple of good deals. Thanks for the links! I also found 15' of 6" flex liner for $129 plus $50 shipping= $180! It's the good SS 316Ti too, not the thin cheap liner. Well, enjoy your day!
Thanks for the post.
Chris
