Vermont Castings Windsor WR2500X02 Wood Fireplace Insert
adelem
1
Beverly, MA
Newbie here, I found a Vermont Castings Windsor WR2500X02 Wood Fireplace Insert for sale near me and I’m wondering if anyone knows this unit and had pros or cons? I know it’s just continued and it’s a non-catalytic unit which you want because we’re just trying out a wood insert and want to see how often we actually would use it. It seems like it’s in good condition and is under $700. We have a brick open fireplace and an 1060 sq foot 1925 bungalow. I’m including a picture of the fireplace and we will be removing the mantle for a more period appropriate one and adding bricks as needed by code. Any input is helpful. Thanks!
  • [Hearth.com] Vermont Castings Windsor WR2500X02 Wood Fireplace Insert
Download the manual and make sure it will fit. It may be ok with the mantel. Measure first to check. The trim clearances are different than the mantel shelf clearance. The insert will need a full, 6" stainless liner installed which will likely need to be insulated.
I'm not sure why you would approach it this way. If your going to do this you should probably pick something that actually works for your situation and not take the approach of this may work and now we have to upgrade a stove that was just installed.
No matter how you look at this your going to need a liner and probably a block off plate. So why hook a stove to that, that may not be great. Your going to need to get wood and property seasoned which is an investment in time and money along with storage. So why invest in that for a stove that my be subpar and needs to be charged out anyway.
I this were me I'd look into a stove that will work in my situation. No matter how you look at this your going to get heat out of a property chosen stove, that will run correctly and not need to be swapped out. So that being said your going to be getting your moneys worth.
Let's say that the installation of the liner is 2500
Is say spending an additional 700 bucks for a used stove that will run well and have a good burn time be worth it.. obviously you going to spend way more then that for a stove that your going to swap into.
If it is in good condition (that's an important if), the Windsor could work. It's a conventional, mid-size, secondary tube design. A Drolet insert will be about 2.5x this cost. Something to consider. What we don't know is how large of an area needs to be heated, how the insert would be used, and whether the OP has a good supply of seasoned wood.
