As the post reads, I keep on reading conflicting information on what type of product to use when insulating interior basement walls, and whether or not to use a vapor barrier. (Had a thread up regarding my furnace, but didn't want to confuse things) Seems like its not a cut dry answer, as it depends on your climate)
1.) I have not completed a heat loss calculation yet (thanks for the tip), but my question is mainly on whether to use rigid foam insulation or bat type insulation.
2.) Also, in the spring/summer, I will be taping plastic to the walls and floor of the basement to determine if I have a moisture issue or condensation issue. (Summertime it smells musty, but no signs of water/leaking....never any puddles after heavy rains)
Foundation is completely below grade, and the ceiling joists in the basement are insulated with R19 Bat insulation. We will be finishing off 2/3rds of the basement.
I have been monitoring temps in the basement, and the coldest I have seen is 53F when it was about 13F outside. (Temps are being taken from the far corner of the basement, furthest away from any light/furnace etc..)
Some things I read states that R10 is needed for the basement, other items I see is R19 is needed.
I would like to go with the rigid foam board insulation, but its max is about R8 for 2" think, so I guess I would be putting up additional layers. (The reason I am thinking about rigid vs bat is that even though we don't get water, and I don't think we have a moisture issue, it does get a musty smell downstairs, and have read that the regid is better versus moisture.)
Again, just looking to see what others have done as I have read so many articles my head is starting to spin, and many of them conflict each other.
Thanks.
Thanks.
! at least 2" is needed to be called a vapor barrier. you can spray more all depends on how much money you have or money you want to save down the road. Spray foam 2" typically takes about 12-15 years to pay for itself over choosing batt insulation keep that in mind. Just make sure to cover the foam with sheetrock or fire barrier. Also when the guys comes to spray leave the house for a day most manufacturer dont want homeowners around for 24hrs. 30% of your heating energy is lost to uninsulated basements food for thought.
