Hi everyone,
Last year I got a Regency 500 which I burn basically 24/7. I absolutely love it and am slowing building up my 3 year supply of wood.
With that said, I have no intentions of not burning wood in the winter. However, something odd happens in my attic that is quite worrisome.
When I burn it gets my house to a cozy 80 something degrees in my den. My living room is above it and that gets to about 73. Above that is my attic. (Raised ranch)
The issue is, when I burn for extended periods of time, I have either a condensation problem, or wet walls on the interior of my attic...only between approximately 2-3 rafters from the exterior wall where the chimney is located. The rest of the attic and the other side of the attic is dry (except for one wet spot near an old chimney that is no longer in use from the old oil furnace/hot water heater which is likely just the fact that the chimney needs some work on the outside)
One thing to note, I do not get this water problem when using my forced air to heat the home. This leads me to believe it may not be a condensation problem. I have done some research on this, but it is hard to get any answers to my specific situation.
Any insight you guys can provide, or anyone you could suggest I bring into the home to inspect the issue would be amazing. I'm not even sure who to ask about this particular issue for expert help.
Love the forums and read it all the time. You guys seem pretty knowledgeable, though this may be outside of your expertise.
Thanks ahead of time!!
