Went out into the Nat'l Forest last weekend. Cut a load of mostly CA Black Oak (hence my user name). Generally only found some smaller broken off branches, 8" max probably. A lot of bending over and cutting to size w/ my 20# saw makes for a workout on the back. I think I'll build me a folding cross buck to take along. This is for next year or the year after depending on the burn rate this winter.
Was a cold day cutting but it was good to get out again. Permit expires here in a couple weeks or so. Probably won't cut out there again till Spring.
Here, the wood permit is good from around May through Nov, but it varies by ranger district slightly (timing of leaf drop in one area cuts it shorter). Otherwise, no felling near roads, they do supply maps of where you can and can't cut, and you're supposed to call the day you go cut to make sure there aren't any other restrictions. Only one time did a ranger ask for my permit, and that was because I was cutting right off a road to a campground. And I mean, right off the road, just parked on the side of the road and started in on a 4 limbed big oak that had fallen down
