You need to split the wood then take a reading. Moisture on the surface evaporates quickly so you won't
get an accurate measurement without splitting first.
Berone said:What do you do when the wood is less than seasoned?
Good point. If the answer is no, leaving the wood in the shed solves both problems.Bigg_Redd said:Berone said:What do you do when the wood is less than seasoned?
I leave it in the woodshed
Do you have next year's wood in now so you won't have to figure this out again next year?
Frostbit said:Well, my method worked quite well for me this year.
I cut and split about a cord and a half of spruce beach driftwood this past late summer. Most of the splits were in the 20-28% moisture content range. As I split the rounds, I tossed and let pile up a large amount of splits (I would guess 3/4 cord) on the flat bed of my double-wide snowmobile trailer. The resulting load resembled a solid T-pee, approximately 9' in diameter at the base, 5' high at the top.
I work in the local diesel-engine run power plant for the electric utility here. We have two large garage bays in the engine rooms. In the summer/early fall, the room temperatures in there easily are in the 90-100 degree range. I took my Polaris 6x6 ATV, hooked up the full trailer load of split wood, and drove it out to my work place, which is 2 miles from my house. (I live in a small town: ATV's are permitted on the road. I ride my ATV to work most every day). I backed the wood into the garage bay and parked the trailer in there for two weeks. I took a large (20") high speed/high volume exhaust fan (used for evacuating smoke from buildings by firemen), placed it on top of a 55-gallon drum about 10 feet from the center of my trailer load of splits, turned it on, and let it run for two weeks. With such a multitude of split surfaces available to the fan, pushing air through and around it all was going well. I moved the fan to the opposite end after a week.
I did this with both loads of wood, and ended up with my partial winter-use supply being down below 10% of moisture. I simply drove the loads home, backed it up to my storage area, and stacked away.
I'm burning the wood as we speak.
I'm going to do it all again next summer, but begin earlier and plan to put up three times what I did this year.
! (86ºF dry bulb, 65º wet bulb reading). Kids, don't try this at home unless you love nosebleeds. Time to mop a couple of buckets of water onto the bone-dry cement floor, maybe squeeze in another cord of green hickory. lolWe use essential cookies to make this site work, and optional cookies to enhance your experience.
