Caw
Absolutely nothing it's 100,000 degrees here in MA (60) in the middle of February. Already made maple syrup once this year the poor trees are confused. Going back to 35/15 cycles after Monday which is more seasonable.
sure there isNo way to find a older stove in your area? Maybe fix it up? Crank that boy loaded with 60lbs of oak? Thats what I did here with my trucks. Found pre emission diesels and fixed them up. Import a giant pig from Russia? Instead of running AK47s you could be the Lord of Wood Stoves to the EU.
I tried to build a fire last night and could not do it...
Over 3 hrs I heated the flue for 10 min with a hair dryer 4 times!
from the firebox it would not draw much at all
wood would not light; I even used firelighters, no joy
this wood isn't wet...there was just no draft
Is it an inversion? I'm halfway up a hillside...we're kind of in a valley...
In the end I had to pull the smouldering wood out of the fire box and dump it in a galvanized tub
emptied the entire stove and set the pieces on the front grass to extinguish
all coals in a metal bin out side
I fear the 90 is already blocked, I gonna hafta dismantle it today and investigate...but it's still raining
and there is no way I gonna be able to tape up the connection if it's wet
I was shocked to see how much creosote has built up in the past 8 weeks since we swept
as I can see inside from the "cleanout"
previously we hadn't swept for 5 mos!
we might hafta buckle up and get ready to get hosed on elec prices cuz burning season is almost finished this year
None of that sounds right at all. I sweep every year because I should not because I have to. I bet I could run for several years before I had problems. You need a stove you can add wood too. Splits not kindling. I loaded my stove at 8pm last night with 6 splits of oak. Woke up this morning like a lazy turd at 7AM threw in a few small splits and 2 6-8 inch splits on top and off she went. You either have a wood problem a stack problem a stove problem or a combo problem. Have you checked the moisture level with a meter? You should not have a creo build up after 8 weeks unless something is not right.sure there is
but, say goodbye to efficiency and hence blasting thru the wood for very little heat gain in the house
the Panadero Delice does heat OK
and, again, the gov't wants us to run our stoves this way because- emissions
I have the old Esse. but that firebox is no bigger than the Panadero...and the Esse is essentially a perforated box...there is zero chance of sealing it up, simply not possible
Been like that here too. Supposed to be in the mid to low 30's here at night for the WeatherUnderground foreseeable future. What that means to me is a lot of kindling and a lot of fat wood. Stove goes cold, stove gets hot, stove goes cold, and on and on. Night time fires increases the labor at least for me.I miss the fire. Been waking up in the 50s.
Well, EcoDesign2022 is what it isNone of that sounds right at all. I sweep every year because I should not because I have to. I bet I could run for several years before I had problems. You need a stove you can add wood too. Splits not kindling. I loaded my stove at 8pm last night with 6 splits of oak. Woke up this morning like a lazy turd at 7AM threw in a few small splits and 2 6-8 inch splits on top and off she went. You either have a wood problem a stack problem a stove problem or a combo problem. Have you checked the moisture level with a meter? You should not have a creo build up after 8 weeks unless something is not right.
![[Hearth.com] What Is In Your Stove Right Now? [Hearth.com] What Is In Your Stove Right Now?](https://www.hearth.com/talk/data/attachments/324/324643-d340d25604ec2dba1014e60d7dac313b.jpg?hash=2rGqnqaxzJ)
😂 My Son was home for college and ate half of my wife’s venison Pastichio. Nice Greek dish and substituted venison instead of Hamburg. Delicious!Had to fight with my youngest son to get a few chops on my plate. Can you guess which is mine? He is a senior in college and still thinks he's a growing boy. Best part of this time of year is sharing time with family sitting round the fire and enjoying good food. I count my blessings everyday
View attachment 324632 View attachment 324633
