Hello every one.
My Whitfield pro 30 would go into default after running for a few hrs. So I cleaned everything. I had the vent apart and cleaned the fans the exhaust flues Checked the door rope and found a week spot so I tightened the door latch and sealed it up.. I ordered a new one today. Checked the door switch and oiled it Checked the Pressure Switch hose, it was good and clear. The PS works as you can hear the click and it had continuity when closed. Checked the Photo eye removed the cap in the hopper and cleaned the lens and filter.... it would still go default. then When I started next ( No thermostat, Manuel start.) It went through two start cycles and then proof of flame and demand side. 10 min later it goes back to start cycle. This happen three times then it finally ran for 2 hrs and default again. I jumped the pressure switch and same thing. Jumped the High Limit same thing. Only by now it would stop after 10 minutes. Then later on I started it, ran it on high heat and it ran for about 4 hrs then default. I also ordered a new Pressure switch today just in cast. I have two other (Drollet ) Stoves EC 45,s one i have had for 9 years and have never been stumped like this. So Any ideas?
