Partly curiosity, but it also matters to some extent for understanding running the stove: what is the factor that makes a cat crash after closing the bypass in a new fire? Obviously it won’t crash if the fire and pipe temps are well over 350F, but at lower temps it might or might not crash sometimes. Usually not.
Theory: the steam in the smoke in a new fire, even from <20% wood sometimes, cools the cat faster than hydrocarbons + heat supports the cat staying lit. Splits just lighting off can put off more steam than heat and hydrocarbons, even when <20%.
To be clear, a crashing cat is pretty rare, but now with a probe in it I can see if it does or doesn’t happen. If it does happen, I watch the temp on the probe go down from say 850F degree by degree to under 600, where I give up on that light-off and open the bypass to get some flames roaring. It’s not like it didn’t really light off. I can see that it’s hot on the probe, and staying over 500F, but the temp goes down and down and down.
The thing is that it might crash with a fairly large load of wood on a new start, but I just burned through the smallest load of wood I’ve ever put in this stove, and got the cat to fire and stay lit.
I decided to have a quick fire with 11 pounds of just sticks under and over an inch in diameter, all hardwood and very dry. I didn’t even think I’d be trying to get the cat to light with a little fire like this. It was burning clean as can be, absolutely no smoke coming out of the chimney (or steam). I was surprised when the pipe got over 300, closed the bypass at 310F, and the cat was 800, very slowly dropped as the fire was already a bit toward coaling. Stayed lit though right into coaling.
With a larger load when I close the bypass and look at my chimney, there is all kinds of steam coming out at that point.
Larger wood has been ash cut split under cover for over a year along with sticks and diluted with pine splits under cover for 6 months.
To be clear, this isn’t as much of a big deal as a matter of curiosity….
