Meh, all that is irrelevant if you just go higher.
Exactly correct.
Bed size doesn’t really matter as, in a 1/2 ton truck you will always run out of weight capacity before bed space, when loading it with freshly cut firewood to haul home. Even that itty-bitty super-short bed, stacked 2 feet deep with rounds, can be 2200 lb. of oak. That’s not evenly distributed between the axles, as in keeping with the maximum payload rating of the vehicle, but directly atop a rear axle and suspension designed for 1000 lb. of weight in the bed.
Go long bed, and it’s possible to stuff 3500 lb. of freshly-cut oak rounds in the bed, without going much over the rails. Again, directly over the rear suspension, not evenly distributed between the axles. That’ll even make a 1 ton squat, a bit.
Yes but none of them are anywhere near the weight of a full cordIt’s been decades since a “half ton” truck was actually 1000# of capacity. It’s all over the board now.
Not really. They’ve all been running pretty close to 2200 lb. total payload for at least 20 years. But again, that’s 2200 lb. evenly distributed between both axles, and including fuel, cabin cargo, and your fat ass. [emoji14]
2200’ish lb. equally distributed between the axles still yields something not far from 1000 lb. in the bed, no matter how you slice it, and way short of a cord of green hardwood.
Really??? Who the hell cares if it will fit but the truck cant handle the weight? There would be absolutly no reason to load a truck full of wood if it wasnt able to move that wood safely. You need to use some common sense as well.The op didn’t ask whether the truck could handle the weight of one cord, just whether it could fit.
Didn’t you guys ever take tech writing classes or even listen to any riddles? Words matter.
Ok tell me any reason you would want to put a cord of wood in a truck that cant move itShould take that up with the OP then. He's the one who asked.![]()
Sometimes you need to help the asker to the correct question, when they ask the wrong one.I don't care if it moves or not. I just answered the question that was asked.
I have some trouble believing that a factory-configured 98 k1500 was rated that low. I owned a 1995 K1500 extended cab 4x4, and remember it having a payload rating of 1800#, something like 4600# curb and 6400# GVWR.Yes really. Look closer. I only had 400# of payload capacity on my 98 k1500!
It'll move it. Explaining why you couldn't stop your vastly overloaded truck to the cops when you run over the kid that just rode his bicycle out in front of you is going to be a humbling experience, though.Ok tell me any reason you would want to put a cord of wood in a truck that cant move it
I haven’t either, but I can do the 2nd grade arithmetic. The sticker lists curb weight and GVWR, the difference in the two being your payload capacity, with all of the aforementioned (fuel, passengers, etc.) included. And with suspension and tires being two of the primary limiting factors, it is intended to be distributed between both axles, not entirely over the rear axle, in the bed of the truck.I have never seen a payload rating on the legal sticker. Are you sure that’s not just marketing bs like “tow rating”?
You know, I think you're right, Highbeam. I was just checking photos online of door jamb stickers, and none have the curb weight. I must have gotten that off the window sticker, at time of purchase, and done the mental math at that time.None of my stickers list curb weight either. I would want to verify that anyway since I may not include options or fuel. The sticker does provide axle and gross ratings. Those plus tire ratings are what the judge will consider, not some holes pokus arithmetic done by the perp using fake numbers.
I think we can agree that you just can't exceed your GVWR, GAWR, or tire ratings and be legal. Weigh when loaded to determine if you're over. A smart guy will weigh when empty so that he can determine his allowable cargo capacity.
I did the half ton thing for several hundred thousand miles. Those trucks are nice riding and give good mpg. I upgraded to the one ton many years ago for the cargo capacity, and the related tongue weight capacity on the hitch.
As trucks have gotten newer, you'll notice the ratings keep going up. There are modern half tons out there with more towing capability than my 2000 F350! It's wild.
