We hit the mother load! :ahhh: Elm dropped and piled up loosely and left for three years! This stuff is dry all the way through 18 inch rounds! We cut a truck load in about 1 1/2 hours. Stuff is solid, and took more then one whack to split, but WOW! There is more wood there I could burn in 5 years just in the one pile/pit. :bug: There are three piles/pits of this stuff, and more branches, up to 10 diameter, then I could possibly use! I will be in Elm for as long as I want to burn wood! The saw went to the shop to have the throttle adjusted,(It kept dying after I finished a cut), But I will be cutting, splitting, and stacking as fast as I can when the weather turns warm! The plan is to cut as much as I can, and stack ahead for years to come. How long will split wood hold if stacked off the ground? ;-)
I have noticed that this elm doesn't burn with the same voracity that the last load did. I believe that even after 3-4 years of weather that this my not be as seasoned as I thought. It is dry, but not seasoned.(no spitting, popping, oozing, or noticeable hissing,while burning, and doesn't have the really dark center like some of the the branches do. I'm saving them for next year.) With the last load, I could load up the stove, let it get good and ripping, and damper back the primary air all the way down to run the load out with just the secondaries firing. I need more air to hold the temp up for secondary firing with the splits from the big 16-18" rounds. Next year is going to be GREAT! This year this will have to do. will burning some Rutland Kwick-shots as directed on the little sticks help control the creosote, now that I'm into the not so seasoned stuff?(copper sulfate and trisodium phosphate)
