Many a round but not much firewood splitting going down. The Good - Honey & Black Locust, and Apricot wood, the Bad - Blue Spruce & Poplar, and the Ugly (medium wood) - Russian Olive, Lodgepole Pine, & Siberian Elm.
Pretty nice Cheery log, right there. As you know, just the sapwood rots, not the meat. 👍I'll need more stacking room but the splits will be moved out of this area since we have a rotting cherry that will come down this summer that is just in back of the logs that are left.
What caused the 20* miss, did the hinge get cut through or was it mis-aimed? If the latter, I've found the aiming line on the side of my Stihl saws to be useful. Not sure if your saws have that...?I started the cut too high on the back. Result the tree fell about 20 degrees from where I was aiming, so grade = C- on that first tree fallen of the year.
Sometimes, if it looks like the back cut will be hard to start correctly, like on a big tree, I'll cut the hinge, then wrap a string around the trunk at the height I want the back cut coming to the hinge. Then I tie the string off and put a line with chalk along the string line.hinge was high on one side and 1" on the other side.
Here's a pic of what I saw on the Shingle Oak behind the house. This sap was all over everything.. leaves, cars, my quad, etc.There is sap dripping from a lot of trees, depositing a sheen on anything that's under them. I guess that's because it's been dry for several weeks, and maybe that's a defense mechanism to hold in moisture.
The Cherry tree is still standing, everything in the pictures was White Pine with the bark removed/fallen off.Pretty nice Cheery log, right there. As you know, just the sapwood rots, not the meat. 👍
Ah, OK.The Cherry tree is still standing, everything in the pictures was White Pine with the bark removed/fallen off.
I'll get a picture of the Cherry tree today, we'll get some firewood out of it but the ants have done a good job on it.
Kinda hard to tell from those pics, but the one with the lighter-colored flats on the bark, left side of the pile, could be a Red Oak type. Can you see the light-colored rays radiating out from the center on the cut end?any feedback on what this is.
No one will be messing with your stash, with those vicious attack dogs on guard duty!6 truck loads of tulip, 3 truck loads of maple and cherry, and 1 load of cedar.
Get it while you can! Nice work @heavy hammer , how has the weather been in your area?View attachment 313362View attachment 313363View attachment 313364View attachment 313365View attachment 313366View attachment 313367View attachment 313368I finally have had some time to get some wood the last couple of weekends. 6 truck loads of tulip, 3 truck loads of maple and cherry, and 1 load of cedar. I have moved about half of it with the tractor. I have been busy with work and kid sports so no time to do wood. Everyone on here seems to be getting a lot and staying very busy.
Nice work @Woody Stover , you're putting up a bunch of firewood.Yesterday I busted the rest of the 'shroomy White Oak, and put it on top of a short stack that I have next to the quad path. That little stack has a bit of everything; Cherry, BL, Hedge, Red Mulberry etc. It's all ready to burn this fall, and is the closest wood to the house.
My main stacks run down the hill and the short stack is at a 45* angle to them. Then I have about five cords in a different area, of BL, White Oak, and a bit of Sugar Maple. Once I burn that, all wood will be stacked in the area I'm working in now. It's more accessible, and gets slightly better air movement.
Short stack:
It's on a base of concrete blocks and timbers, four rows deep, with two longer rows closest to the camera, and two shorter rows behind them.
These are two of the three main stacks in that area:
It's hard to see, but one log is visible of the stack base, uphill of the right-hand stack under the leaning pallet. I was pulling from the top end of that stack last winter..hard Maple.
The stack on the left is mostly Red Maple, with a little of the 'shroomy White visible at the top where I filled in from what I grabbed last winter. That's 10' sheet metal on top.
As you can see, in this area I have plenty of room to extend the three stacks down the hill as needed. Where you see the sheet metal in the distance, it drops into a ravine behind there..
Today I split the Hickory shown in #534, and stacked it where the 'shroomy White Oak rounds were. I removed the wooden pallets, left the concrete blocks in place, and put down two plastic pallets that a friend gave me. They are 44x48", and heavy-duty. This is the beginning of the third main stack, where I'll have high-output wood--White Oak, BL, Persimmon, Red Mulberry...and Hickory of course. This stack is parallel to the other two next to it, and all have enough room between them so that I can drive the quad and trailer though to load and unload.
Being on a slope, a row slid on the plastic pallets a couple of times so I got some long deck screws and put one in one of the holes in the pallets every so often. One is visible at the end of the second row if you zoom in.
You can see some White Oak splits on the left. I had about five rounds, from a fallen branch I got when I was working on the uprooted White that was propped up off the ground on a branch, a few months back. All the sapwood was gone, and it had that sweet vanilla aroma when I split it today. 🤗
This is the second quad trailer load of Hickory/White. It's heaped about as high as possible--good thing I only had to drive about 50' to the pallets.
I'm no thewoodlands, but I've been getting some lately. Like you say, "It adds up." 👍 I guess what I put on the plastic pallets yesterday might be 1/3 cord or so.Nice work @Woody Stover , you're putting up a bunch of firewood.
I should change that to theolderwoodlands I'll put up another face cord of pine and then if the heat isn't that bad, start working on some downed hardwood again but only after removing four or five stumps with the 4540.I'm no thewoodlands, but I've been getting some lately. Like you say, "It adds up." 👍 I guess what I put on the plastic pallets yesterday might be 1/3 cord or so.
I've got some other stuff to do right now, but I'll be stacking more before long, both here and at the SILs. And whenever Vistaguy gets caught up on stacking, we'll saw him some more of the Shingle Oak that he can haul home. He's loving how easy it is to split, compared to the twisty hard Maple we got him earlier.
If this mild weather would hold, it'd be great, but I'll be out there no matter what.
I've got plenty of wood here to work on, but for some reason I can't resist a good off-site scrounge when I stumble into it, especially if it's a wood that's more scarce here at our place. We have more dead Red Oak than you can shake a stick at. 😏
Wild honeysuckle.No work outside because of the smoke but after sharpening three chains on the grinder, I took a walk down the driveway, yesterday we had a chit load of swallowtails on this, today not so many. What type of bush or whatever is this?
Took a few of the sun but didn't come out that great.
View attachment 313149 View attachment 313150 View attachment 313151 View attachment 313152 View attachment 313153 View attachment 313154
