Yes the chimney will cool some as the coals burn down. But that doesnt matter. I would not add wood at that point unless i needed more heat or i was going to bed or to work.View attachment 233545 Been burning 5 hours, red hot coals. can barely keep hand next to open door for more than a second. is it time to add a full load for nighttime? or get some more heat from the coals first?
shouldnt i not allow the coals to burn down too much as it will cause the chimney to cool?![]()
Looks like coals when I go out on the porch to have a half cigar before bed. I come in after my cigar, close the air to low, and go to bed. I don't burn overnight.![]()
When the stove is at this coaling stage no creosote is being created. It's ok for the chimney to cool down a bit at this stage.View attachment 233545
I usually turn it up and burn the coals down. Try and time it so when the coals are burned down it's time to load it up before bed. Takes practice.When coaling you keep the air off correct?
doesnt your house get cold? my house at 78F without burning id wake up at 63 or lower 8 hours later and my house is beyond insulated![]()
Every time I open the door when my coals look like that I get blasted by heat. I’ve been tempted to just leave door open and let it radiate into the room, supervised of course. I imagine that’s probably not how the stoves were designed, so I haven’t done it. But exactly how bad of an idea is it?
Hahah way to lead people on...Looks like coals when I go out on the porch to have a half cigar before bed. I come in after my cigar, close the air to low, and go to bed. I don't burn overnight.![]()
i think you can do that but you then have a problem of possible carbon monoxide in the house, no?
Bad idea. serious threat of carbon monoxide poisoning.Every time I open the door when my coals look like that I get blasted by heat. I’ve been tempted to just leave door open and let it radiate into the room, supervised of course. I imagine that’s probably not how the stoves were designed, so I haven’t done it. But exactly how bad of an idea is it?
I left my door open one afternoon to let the hot coals warm up the room. Luckily I have a co detector & it started alarming, the levels were at a dangerous level. I had to air out the house and reheat.
Without a co alarm, it could have been a bad day. If someone tried this before going to bed it could be fatal.
My situation right now. Staying up late to burn down some coals for a reload for bed.
