1991 country s310 stove! Need help
Georgia66
4
Idaho
hi . I moved into a home and this is the stove that came with the home. I’m trying to find specs on this stove as I would like to know all about it. Can anyone help me find those specs?
Thanks .
As you can tell this is all new to me!
This stove is still for sale under the Ironstrike brand. It's known as the Country Canyon, made in Auburn, WA. It's a good stove and a serious big heater. Given its age it would be good to have the door gasket checked while you are having the chimney cleaned and checked for safe operation by a certified chimney sweep. The manual and more information can be found here:
(broken link removed to http://ironstrike.us.com/products/canyon-310)
they are thick steel stoves.
Yeah, it's a beast. Weighs almost as much as the T6 and it doesn't have a cast iron jacket.
What does that mean exactly? Does thick steel hold heat well?
It means the stove has a lot of mass and is built like a tank. The mass of steel will take a little longer to warm up, but it will continue. radiate heat after the fire dies down.
I’m also looking for a Manuel for it. Can’t find anyone on the web.
The manual is on the Ironstrike page that I provided the link for. Look under the documents tab on the lower part of the page.
This is my only source of heat.
Have you ever heated with wood? Do you have a large amount of fully seasoned, dry wood already split and stacked and top covered for winter heating?
I do have some wood and am currently working on getting more! Thanks for the information. I truly have appreciated it!
Do your best to get seasoned firewood. Poorly seasoned wood puts out a lot less heat and gunks up the chimney with creosote.
Thanks .
I just moved into a home with this stove. Were you able to find any info? I need fire bricks and baffles
Is your stove the freestander? The manual is listed on Ironstrike's website support under Canyon ST310. It's the 2018 manual, but the Canyon didn't undergo a lot of updates since introduction. However, it has a newer baffle with more insulation.
Here is the Canyon's brick arrangement under its previous Lennox ownership with the older baffle style.
[Hearth.com] 1991 country s310 stove! Need help
