Yeah, you keep talking about how deep your box is. Personally I prefer a deeper box to a bigger box. But most important is the seal.We are not normal. We are stove enthusiasts.
Just don't pee on the stove.
Also getting closer to pulling the trigger on an ash pan.
I don't like the ash can in the house. Full size coal shovel into the stove and walk it right out the door before it goes in the can.
what do you think the actual Cat. temp. really is? And does this shorten the life of the Cat.?I have seen that vid., thought it was a lil' silly to me.Anyone recall a video from about 3-4 years ago of a fellow in his shop showing off his new Blaze King. Shut down the damper and placed his hand into the vent. Was impressive. I am jealous of all you BK owners. I shoudda woudda coudda ordered a BK when I installed a new stove here 5 years ago. I didn't and know I am burning twice as much wood for less heat.... sigh.
It can't be due to fire safety! No way no how is walking a full size coal shovel through the house safer than an ash bucket with a cover.![]()
S&W, nice to see you back.
Ash can gets filled up, then outside for a few weeks, until the next time I need to empty the stove. Dump the exsiting contents in the ash pit, then clean the stove and repeat.
SWITCH-- diff. direction--
I have one of those Cat. temp. probes that tells you the "actual" temps., vs. the -active-inactive- probes.
With the blower off I can keep a stable temp. for a long time, say 1500 on the Cat. probe.
With the blower on, I can do the same thing, but for a shorter duration. But...
Since the air is passing over, and cooling the top of the stove, AND cooling the probe in the process, if the probe is maintaining 1500what do you think the actual Cat. temp. really is? And does this shorten the life of the Cat.?
With the t-stat closed and well into a burn do you guys see any flames at all?
I now notice some real small flames now and then coming off the wood even after hours into a burn that I don't remember seeing before.
Door seems to pass the dollar test ok.
I'm 3 hours in right now and the ir temp is 550 in front of the probe...cat is bright orange but I have seen it brighter.
All seems fine but I do see some flames here and there...small but there.
I have needed to run the stove at higher settings recently, right at #2 which is 50% throttle for several hours. At first there are some flames, maybe a couple hours but then it goes to cigar burn mode and I get a significant glow but no flame. So I don't even get flames at higher settings. I can't imagine how a woodstock can have flames for the majority of the burn without overheating.
Do those with OAK see a difference in burn characteristics when you turn the fans on? I do almost immediately, but I wonder if it has more to do with the fact that the intakes for the blowers is right next to the intake for the thermostat.
Oh I tend to agree with everything you just said.
Do you think if the door gasket is leaking that it would make the cat burn to hot or the cool air coming in is what is hard on the cat?
The door latch on mine broke when I tried to ajust it.
