On the Princess Ultra, does anyone notice that burn times really suffer when its windy outside? And also does your stove burn right down to ashes each time, or do you end up with a big pile of dormant coals? Im trying to burn a bit hotter as iam wonder if running my fans on low all the time is cooling the stove too much, causing all the coals and the lousy burn times. I need to run the fans to circulate the heat in my large house tho.
Iv had nothing but problems with this unit, poor service and no dealer help at all. He wouldnt even return my phone calls! I Had to change the thermostat by myself and troubleshoot why it was overfiring on me. Found the bypass plate very loose causing way too much draft, and my door was slightly loose. Then when i changed the thermo i found it half ass sealed causing the air whistle noise that was very annoying and explaning why it would still take off on me when the damper was shut. Now after i changed out the thermo (all sealed up now), and snugged everything up it works all together different.
My setup definitely drafts harder in windy conditions. Kinda self-regulating, I guess, because I need more heat at those times. As for the fans, I can't really tell. If I'm running them, I need more heat and I am burning the stove hotter.
I pretty much burn down to ash. A few really small pieces of charcoal, maybe. This is where really dry wood comes to play.
I have found the Blaze King dealer network to pretty much suck. The dealer where I bought my stove is clueless. When I was trying to order parts for a used stove, it took a few more tries to find a dealer who would even try to help me. I did find one about an hour and a half away that seems really good. I know where to call the next time, and the first three will never hear from me again.
