Mr. Jones
That's the intake, yes. Once it gets inside, where's the outlet? Usually there's tubes for an air wash system. I don't see any tubes.Claybe did a good job answering this in post #171
I don't see any tubes inside the princess. Does it come in through the front right side, and just enter behind the firebricks? I went through the online manual, and couldn't find any info or drawings on it.
My lopi has them. Part of the airwash system. I know what they look like. No tubes. This is the princess insert. It must just come out in the lower fron,t below the door, and behind the firebricks. I've looked at the online manual, and don't see anything, including pics of any tubes.
I've also noticed there's also metal "tabs" on both sides of the cat. I don't see any info on those either in the manual. What the manual does talk about is different "tabs" that's helps hold the cat into place. These are on the other side of those. Some sort of air diverter, or blocker I guess. It's thin metal, not attached to the top, so it wiggles if you touch it.
Ho ho! Scouts at the National Weather Service have sighted our first stove night here!
I have the princess so I'm not sure this will work for you but it's very simple. In between the two fans is the thermostat housing. Mine had a sticker on it saying do not remove this cover. It's held on by 2 screws and possibly a blob of silicone. Pull that off and lube where the shaft rotates with nickel anti-seize. If I remember correctly I used a little acid brush. I was told don't worry about reapplying any silicone when you reinstall it. Btw nice swoosh stickerCan someone please lead me to the link to lubricate the air control on my King? I have the fans.View attachment 184301
Stove pipe is all painted andI don't want to reinstall it without doing this. Thanks!
https://www.hearth.com/talk/threads...rformance-thread-everything-bk.145814/page-66 Post 1635 is where it's atCan someone please lead me to the link to lubricate the air control on my King? I have the fans.View attachment 184301
42....that's a nice summer night. No need for a fire, just snuggle up with the Mrs.....I am just jealous. We have a rule to only start a fire when it dips into the 30s. Looks like it's a ways off for me!
Pic of the new steelcat. I'm going to hold out judgment on it NOT having a gasket for now. The only instructions is "do not use a gasket, just put it in leaving room for expansion." I found that I have about 1/4" gap between the top of the cat and the stove but after an e-mail inquiry was told that was fine.
My steel cat came with a new gasket. I would acquire the required gasket and think that this is another case of a dealer more concerned with profit than making it right. The cat does look like durafoil though.
I ordered a steelcat from them too. It will be here Monday. I will see how mine fits. I read that no other gasket is neededAgreed, I will get a gasket but am going to try it without just from curiousity. I don't see it expanding to the point of closing that kind of gap but only one way to find out.
The sides are fairly snug but since they advice not to use a gasket I think at least putting a lip across the top of the cat would have been better.
The silly electrical unit turns itself off every 2 minutes
Wonderfully, the BKs use the elegantly simple and reliable mechanical indicator. The go/no go scale is great. Could not be easier to use.
...my previous stove was a "downdraft" type burner and required at least 20 minutes before damper rollover. An early rollover would result in a cat ignite failure and a lot of smoke at the flue cap. Eventually I purchased an electronic cat thermometer so start-ups were not done blindly. A mechanical thermometer could not be used as it was inserted at the rear of the stove. I was not happy with that situation at all.
