Lokidric
Almost all of my axes were made in Germany or Sweden. Obviously the Canadian made ones are the best
Umm, so now what. Stove has been running great.
I had one miscue in the first couple burns letting the cat indicator get above the active area on dial. Since then, I turn the convection fans on to high as I close the bypass door. Haven't seen the cat temp indicator higher than 3/4 up into the active zone since.
Last night got the bypass door closed and the cat never lit off. No ghost flames, most of the visible flame was headed for the closed bypass door, wasn't putting out heat like I am used to. Let it burn out overnight.
With the telescope pipe up out of the way, there are no visible chunks on the bypass door gasket. I have had that problem before. Something half the size of a pencil eraser is plenty big to keep the cat from lighting off.
Checking with a 600 lumen flashlight inside the cold firebox and me looking down from above, bypass door is light tight when closed, seems to still be flat and square to the bypass opening.
Cat is not visibly plugged, light passes through around that whopper heat sink behind the cat just fine. Fine grey ash accumulation behind the cat in front of the bypass door looks normal.
My flame shield for the cat is warped at least half an inch is the only thing I can find "wrong" with the stove - other than it heats the house like the cat isn't working.
Now what?
EDIT: I went poking a little bit. I first lit the stove this fall on Sept 6, was burning about every third day after that, see post #45. The one time the indicator rose above the active zone was 09-17-16 would have been the third or fourth fire of the year, been burning a full load every night since I think last Wednesday, we had a really damp overcast rainy bone biting chill kinda day and it hasn't really warmed back up since, so five nights in a row working good and then bam, like a switch, less heat than I am used to.
If your chimney cap has a screen or spark arrestor, check that first. Second, you need to maintain enough draft to keep the flue from stalling. In new applications, often its the spark arrestor.....and others will tell you how they addressed that issue, if you have one.Is it normal to have smoke coming out the back of my Chinook?
Lit a fire last night,got the cat active and turned down to about 1.5 overnight.
Temps were in the mid 40s.My plan was to let it burn out by morning.
Stove was still warm with a small amount of fuel left so I opened bypass and turned it up before my shower,came down to the light smoke puffing somewhere out the back(I have the blowers so not sure exactly where.I just turned everything down/closed bypass.Is this just because of the cool chimney pipe?
Sounds like your single wall chimney pipe paint was curing, was it a fire smoke smell or paint / metallic peanut oil smell?Lit a fire last night,got the cat active and turned down to about 1.5 overnight.
Tee system, not very cold outside, no flames in the box. I'm going to say you had no draft established when you tried to revive the fire.Is it normal to have smoke coming out the back of my Chinook?
I wonder if the fan running on high was actually doing anything to keep the cat running cooler or was it just helping to cool the probe thermometer itself, giving you a false reading. If so, you probably fried the cat.
This is by far the safest and easiest stove I have ran but I have a theory that by running the stove hard with the fans on high the fans could actually cool, trick, the thermostat making it possible to overfire the stove.
Correct. The fans cool the coil on the cat probe meter so it indicates lower but don't cool the cat much if at all. The bk is engineered to prevent overfiring the cat. Cat failures are 95% caused by leaky door gaskets.
Just run it. If the cat meter is in the active range or higher then the cat is working as best it can. It doesn't have to glow and in my experience doesn't always produce clear smoke.
For sure if you still have a spark screen at the cap, that's where you start checking. Then wood quality.
@tarzan , I am not sure.
I have kept @BKVP in the loop since my solar wood kilns were in the design phase.
It sounds like my cordwood is about the same MC as the NIELs ( north idaho energy logs) that BK is corporately familiar with and BKVP's wife prefers to run when he is travelling.
So beta testing a little, yes, but not completely beyond the pale.
I too think my cat is roasted, unsure of mechanism and should dollar bill test the bypass gasket before i relight it.
Cleaned the princess insert this weekend and found some more missing pieces of the cat. Will it be okay or should I be in the market for a steel cat???
No,it was visible white smoke.Sounds like your single wall chimney pipe paint was curing, was it a fire smoke smell or paint / metallic peanut oil smell?
Unless the cat actually falls apart it is fine with chips, cracks, and weird colors. Be sure the meter goes active, and that the holes are not clogged.
Sounds like the warpage is the real root of your problem. Even with a smashed flat gasket they almost always pass the bill test due to the weight of the bypass plate. Going with a 1" gasket is a huge jump! And adding more glue isn't good either, the glue soaks into the gasket making it very hard.My bypass gasket was bad enough that I was able to pull and push a dollar back n forth. It's better now, but since I've got it out, and waiting on a new cat, I was thinking about re doing it with bigger gasket. It calls for five eights. I'm thinking about jumping to 1 inch, since my baffle is a little warped. I'll keep trying the bill test all around, and fill the loose spots with more glue, until it's all evenly harder to pull the bill through. It's a pain in the rear, but it's necessary to get the stove to work right. The magic in these stoves is an air tight box where the bypass and cat entrance is.
