Shayne
With my new (overactive) cat I see the cat thermometer needle on the outside of the active range from time to time. Worth noting FWIW, I never seen this with the ceramic cat.
I don't worry about it any more. I just run the stove the way I need to run the stove to heat my home and if the cat lasts two years or ten I'm just going to get another and keep going. The stove is absolutely that good!
When you look at new BK's in a stove shop you'll notice that the only numbers left on them to cause worry is the price tag!![]()
TY TZ, I have a ceramic and it is real easy to get it above the active zone with the hardwood I have here, nice and dry and aged, no moisture meter required
. @ a few hundred a pop it would be nice to get some feed back on the exact does and don'ts from someone that knows.So r you running a steel cat now and how long did the your ceramic last, between both which works the best and which lasts longer in your case?
I think I only know part of the answer.
When I said full throttle I meant top of the swoosh, highest numbered position on the Tstat, NOT up past the top onto the hard stop.
Second, i think the fan kit probably does cool the coil on the cat probe a leetle tiny bit, but running the fan kit flat out pulls a LOT of heat off the stove, i can feel it and measure it in my back bedrooms far away from the stove room.
So top of the swoosh Tstat, fan kit wide open, my cat probe needle stays at or near the top of the active range until the wood gas is out of the load and the coals are starting to burn down.
Do you have a convection deck fan kit on your stove Shayne?
I understand and never thought of going past 6 o'clock on the knob (high swoosh), I use ecofans and strategically placed DC ceiling fans throughout the house, we never contemplated an electric fan on the stove due to noise. Two eco's up top do cool the stove down a bit and get the air moving but maybe not to the same extent?
Definitely purchased the convection deck add-on to help the eco fans, it makes no noise at all
......I do believe that my operating experience would be better with more draft but the only time I really notice a problem is when I get smoke spillage after opening the door when the stove is still partially loaded with burning fuel ......
No worries HB you will get the hang of it eventually
Joke. Crack the door really slow, leave it just a jar (1/4 to 1/2") for a bit if it looks like it is going to be a problem, make sure it is drafting before you open it and then do that slow, if it wants to come back close it again to a crack and repeat, this the key. Let the home air enter the stove instead of the other way around, it is drafting fine until you open the door or your stove would be dead, choked by smoke, therefore you should be able to open the door without spillage as the draft is already established.How do you perfectly "adjust" your gasket? Hear make sure you adjust your gasket right but how do you poke around the rope?
Regards
Pretty stove, especially in the brown enamel, and cool convection fins on top of the firebox. But it's a 3 cu.ft. stove so you would probably have to run short loads in moderate weather to keep from roasting yourself out. I think it likes to run warm, as well.
