2025/26 VC performance discussion thread
This is how I do it. STT, I have 3 magnetics on it in 3 different positions. Don't ask me why...I trust the one on the griddle the most. The other 2 are cheap amazon ones and they just ended up there and I kind of like it so they've stayed there. But as you can see from the picture of the stove top, they all are reading around 500 right now. I do have an IR gun, I rarely use it. But I just scanned near all 3 of those magnetics and I'm getting readings from those locations between 460-520 degrees F. If I have a left to right burn going on, I'll see the left most magnetic hotter than the other 2 which then fades as the burn progresses. Vice versa if I have a right to left thing going on, but my stove seems to almost always burn left to right.
So yesterday it was warm here, in the 40s. And I did end up taking the time to sweep my chimney, mostly soot, not a lot. I also emptied my ash pan which we'll see if that comes back to bite me or not. I put the brand new catalyst in and decided I'd light a fire this morning which I did around 5am. Colder here today in the 20s and windy. The new Cat lit off like a rocket and scared the poop out of me. The Auber was counting up by like 30 and 40 degrees at a clip which I hadn't seen in a long while. I thought ohh great, here we go - I'll be emailing midwest hearth by the end of the week. But she trailed off and hung out in the high 1200s and I was able to relax. I've been running some smaller loads today (3-4 medium splits) in consideration of that ash pan and a brand new cat. I'll probably put in a similar sized load in after dinner tonight but I'm not expecting that to heat all night and the oil will take over at some point. Stove glass is a bit boogered up but it'll either burn off or I'll clean it tomorrow.
  • [Hearth.com] 2025/26 VC performance discussion thread
Reactions: arnermd and Todd
Thinking the stove has been going well with the cold air so far this December, I had an interesting over night burn and afternoon burn today.
Ash pan is full, I emptied the box 2 days ago. New ceramic cat about 1 month old. Outside temps in the 20s with winds 20 mph.
At 9pm, I loaded the stove 3/4 full of med/large dry maple on a hot reload. At 1000, I turned primary down to 50%, at 1200 I turned it down to 10% open and let it go for the night. All seemed well at 11pm. I woke at 3am and noticed the cat temp was 374. So I went and checked. Stove was all black charcoal. I tried to add another split thinking it might all crumble, but had to push the split in as the box was still quite full. I turned the primary up to 30%, in a few minutes the cat hit 800 and I went back to bed. My wife got up at 6am and the cat was at ~600, she opened the bypass, burned off the glass, added a few splits and closed the bypass.
Why did the temp crash but still have a full charcoal load in the box? I've not had that happen before.
I let the wood in the stove burn down today, This afternoon I wanted test out a full load as I typically only do 3 splits at a time during the day. At 2:20pm I loaded the stove at least 3/4 using the same med/large dry maple on a hot reload. I tested a fresh split, the middle was 14.5%, closer to the ends was < 14%. Within 5 minutes the cat hit 1000, I turned the primary down to 50%. A few minutes later the cat hit 1200, I turned the primary down to 10% open. The cat continued to climb over the next 30 minutes. It hit 1600, so I closed the primary. Cat continued to climb. About an hour into the burn, the cat hit 1684 and then over the next 5 minutes it went down to 1660. I thought I was in the clear, but then over the next 5 minutes it quickly rose to 1702. STT 510. It then quickly dropped in 8 minutes to 1500 at which time the stove started back puffing. At 1450, I turned primary up to 50% and it stopped back puffing. STT 550. Cat continued a steady drop and at 6:30pm it was at 600 and the box was mostly burned down. I then added 3 more splits. So a 4 hour burn time.
Did I not learn my lesson and I should have left the primary at 10% open? Choking it down causes more smoke which causes the cat to rise. But then when the temp was coming down to 1500 why did it start back puffing?
Is the wood too dry?
Whatever is feeding or not feeding air to the cat is still a mystery! I can clearly hear the cat accelerating like when you open the door and the fire surges.
Two similar burns but two very different results.
Welcome to the nightmare..... I empathize completely, I have experienced the same over the years. Might be time to call a priest.
  • Near full box of charred wood: I have had this happen before, but it is pretty rare. I do not know why.... I think typically it happens on low draft days.
  • Backpuffing with Cat > 1500: this happens to me quite frequently, in fact it is happening right now.... I do not know why.
    • A theory: Maybe there is so much hot smoke going through the cat and secondary passages that the pressure in the primary box is not low enough to draw enough air in consistently?
  • Wood too dry?: I doubt it. 14% seems fine to me, but @Woodsplitter67 is my go to expert on wood drying....
  • Cat Noise: There is a distinctive combustion noise that many have reported hearing when cat temps run away. For me it has been a very reliable indicator, if I hear the noise it is going to be a hyper active burn.... no noise and it will be nice and easy.
    • I suspect the noise may be related to my theory above, maybe the noise indicates elevated gas velocity in the secondary combustion and thus more pressure drop through the cat?
Sadly I do not have the answers we all seek.... would be really nice if VC would explain it. The inconsistency is maddening.
If I remember correctly @arnermd has a STT probe that runs a little cooler, I could be wrong but I think that was the case. @Smokey Da Bears, what does your STT typically run at when you're cruising? When I'm cruising my STT is usually about 475-500 with the Auber TC-K-MAG probe but an IR gun says that range is 575-625. So which one is right?
Wow! What a memory! You are correct that my STT reads on the low side. Since last year though I have calibrated it with my IR gun and a bimetal (which both agree within ~30F) and I now correct the reading in my spreadsheet. The legend says "Corr Griddle" which is short for corrected. So the temps in the plot should be accurate as is. I have found a lot of temp variation across the griddle though depending on what kind of burn is happening. I have found variations of 100F between left, right and center as well as front to back.....
Things have been going pretty well so far this year. I've let the ash pan fill up and haven't put more than 3 splits in at a time so the cat hasn't had the chance to run away on me. Today the high is 1 and I don't plan to be anywhere so I may load er up and see how it goes.
So far the most exciting part of this year is my 10 year old son has taken quite the interest in the whole process of the stove. He's been starting it, loading it, and watching the thermometers. Having him involved in this hadn't even crossed my mind before.
Iv had wood.in my stove as low as 3% and it burned fine.. it was a hot fire but not out of control back puffing and super high cat temps
Me personally I probably would have done nothing. Just let it run it's course
Reactions: dmccoole
Yesterday I switched from my ceramic cat back to my old tired metal cat (has about 1 season on it). Notice the difference in the two burns.....
  • Ceramic Cat: this was a 3/4 load, cat rocketed up to 1600 and stayed there for an hour..... Flue gas temp hit 800+
    • Temp dropped a lot after reducing the air, I probably closed it down too fast, but I had sh*t to do!
    • I did close my key damper to bring draft down from 0.15 to 0.8 iwc at 8:10. It helped for a bit but the temps slowly climbed back up to 1600+ before relenting.
  • The metal cat run was a full load, took a lot longer to come up to temp and it only saw 1600 for a short period of time. I would call this a good burn.
I actually came here to report a similar experience this weekend, I'm both surprised and relieved to see others are having the same thing happen.
I am leaving my ash pan full this year, sealed up some leaks in my chimney connectors, and have been having what I would consider a pretty successful start to the season. Predictable burns, nothing alarming or out of control. My wife was home from work Friday so we had the stove running 3 days straight, there were enough coals each morning to light off relatively quickly. Sunday evening the temperature was falling from about 30°F to about 20°F at 10PM when we went to bed. I had reloaded the stove and left the primary air at about 30-40% to get a little more heat out before turning it down for the night. I had STT of about 550-600 (max I want to run), but my cat was about 400 and the flue gas was only about 200. I could not have turned the air up any more, I would have overheated the firebox. I tried turning the air down a bit, that caused the STT to drop down to 450-500, cat dropped to 375, flue dropped to 180. My theory is that the substantial bed of coals that built up over 3 days was actually blocking the air holes into the secondary combustion chamber, causing the cat to run cool. But shouldn't it have been able to get all the air it could ever want through the massive hole in the back of the stove? I plan to clean out the stove and check the cat tonight once everything cools down. I'm using a metal cat installed this fall, as my original ceramic cat crumbled after 3 burn seasons. Probably around 200hrs of burn time on this cat so far this year
That's plausible. Thinking the same, when the fire box is full-ish, I pull the ash away from the air holes area and then try to only push back the hot coals.
I had a similar experience this AM, here is what I observed with my stove, maybe it applies to your adventure....
  • I had a fresh load of big splits, small bed of coals, air wide open, damper closed
  • Cat got to 1000, started closing down the air in steps.
  • Set air 20% open with cat ~1100 and left it there
  • 15 minutes later saw a window full of flames, cat crashed to 600 (I think a lot of loose wood / bark caught at the the same time)
  • STT went to 550 which closed the primary air flapper via the bimetal thermostat.
  • With cat cold and no air at all, cat just hung there crashed.... waited a bit, let the STT come down and then opened the air full and started heating up the cat again. Got it to 1000 and started closing down the air again, this time the cat stayed > 1000.
Regarding that big hole in the back.... It feeds a bunch of smaller holes, some of which are the ones you see at the bottom of the fireback. See the link below for pictures of the secondary flow path.
VC Defiant 2n1 Secondary Flow
Reactions: davargo
Last nights crapshow.... yes that is 1837F on the cat and 1328 on the flue gas.
Full load, set the air to 30% at 22:00 and went to bed.... Woke up to temp alarms, just sat there and watched it, never touched a thing.
  • Wow
Reactions: Smokey Da Bears
That's wild! Sorry to hear. Will you let the stove cool and check out that catalyst? I'm curious to see it.
I've been moving pretty slow with my stove the last few days considering I fully cleaned the stove and put a new metal catalyst in there. Light off on this Cat is super fast from a cold start, which maybe should have been a quicker indicator for me that my last cat was dead. Loads to the stove have been on the more medium/moderate size while I've been home and while I've got some coals in the morning, the stove is basically cold. I think my strategy is to build that ash back up before loading it up again.
I did hit 1530 yesterday on the catalyst and it hung there for about an hour, right at dinner time which was fun for my wife as I kept going up and down the basement steps and the kids are in Christmas Crazy mode these last few days.
Was very cold yesterday and the stove kept the house about 67 without kicking on the oil heat, so I was pretty happy with that. The oil is only really running at night. Gotta keep my focus on the true enemy - the oil!
Reactions: Turbo89
Cat pics.... In general it seems to be in pretty good shape. Frame is generally straight and square but the substrate is clearly stressed and bulging. I am surprised it looks this good to be honest. Unfortunately I could not get it over 600F today so I think it is dead....
Refractory seems to be OK, I could not find any obvious cracks... so thats good. Definitley showing its age with some pitting and spalling on the surface though,
Put my first metal cat back in tonight, see if I can get some more life out of that one.
I've had it happen this bad once before. The only thing that really worried me was my flue it just over 1300. My cat took it like a champ though, no visible distortions or issues.
