The VC Encore Flexburn has arrived. Rather than post on a VC blog, let's try this about the newer product.
So, can a manufacturer with poor QC past like Vermont Castings, change their product quality and service ?
First impressions before we actually burn the thing:
The look and exterior casts are exactly the same as the older Defiant Encore 2550. Visited 2 friends with well used Encore 2550 cat stoves to check on the old model.
This Encore came with bottom and rear heat shields ( a pain the a$$ to install ), a cat thermo probe to plug into the rear ( advice: should I install it , or just use a stove top thermometer ? ), nice installation manual with pics.
The stove is her blue/black "Twilight" enamel.
No secondary air thermo control like on the 2550. Unable to find where secondary air would be. Ideas ?
Reinforcement of the cat damper.
Better ash pan latch--a 'rolling' latch lock.
The so-called refractory assembly is now a hard material , maybe FG rather than the older soft, breakable stuff that 2550 people hated.
The refractory panels are no tool access to the cat. Pull out panels, simple for cat removal or cleaning.
Specs say that the cat can be removed for "non cat" burning.
The cat is 1/2 the thickness of the older cats ( questionable durablity ?). BUT, VC/HHT warranties the cat for 3 full years, not prorated like other cat makers.
The cast quality is excellent, similar to Jotul.
Primary air inlet is now a closed vented 'box'.
Finally, the VC/HHT warranty has expanded in parts and length of guarantee. It's all in the manual.
The only problem was installing the heat shields. The dealer emailed the solution from VC within an hour.
As you guys say, "it isn't real without pics. " When the Encore is installed and burning this weekend, there will be pics and review. The cracked Oslo has been sold with full disclosure of the problem. It is going to a seasonal hunting camp.
