Best Corner Fans for Moving Air
gdisarcina
11
NW of Boston
I need to get a corner fan for my fireplace room and would like to know what are the best ones out there. Thanks for your help!!
Hello Clyde
I also have Entree Air fan mounted in the corner of the doorway. However to make it more automatic I wired it to the cooling contacts on a Honeywell Line voltage SPDT thermostat set to 74 degrees!
My thermostat is an older model but this should do it:
http://www.pexsupply.com/Honeywell-...ne-Voltage-Thermostat-2+Heat-2-cool-46-to-84F
So when the room air goes above 74 Degrees the fan automatically turns on and distributes the heat.
Also for easy control I mounted a fan speed control and 2 wall switches.
The top switch connects the fan to the thermostat for auto operation.
The bottom switch turns the fan on manually. (I always like the old manual override feature!! LOL)
See pics below:
For 25 years I used the Minuteman fan. It still works fine but I just had to go get a Entree Fan a couple of years ago. Noisiest damned thing I ever heard in my life. I have to confess though that when I shut if off I discovered that air convection in this barn is better than I ever gave it credit for and now I don't use either one.
http://www.nextag.com/Minuteman-F-10-Room-622180187/prices-html
The oft suggested practice here on the forum of putting a small box fan low in a doorway blowing the cold air into the stove room works a lot better than trying to move the hot air out. Try it. It works.
87F? That room is really hot.
Hello BeGreen
Yes, that is my basement room 87.5 Degrees F. The fan blows the air upstairs in this split and it is about 70 Degrees F upstairs.
Outside is 23 Degrees F!!
