I started off with ash that was 20% MC last year, covered single row. Most of it was 14-15% MC this year. One week I did throw in a few partially covered beech logs with 35% ends and they were certainly killing the flame much easier. I've purged those out and it has helped. Yes, someone has mentioned the wood quality in one of these 200 postsI hate to be that guy, but I think your wood had too much moisture. The only way you are killing a fire below 80% draft with 20'+ chimney is with marginal wood. This is my first year of burning full time and I have this issue too. Try getting some bio bricks or similar and see if you still have the issue. I need very little draft for those little guys to take off and provide a ton of heat.
If I were going to buy bio bricks at $125/ton I would save about $50/ton running my NG boiler!
I'm sitting here now with STT around 450°F, tstat at 80%, 34°F out/ 72°F in, stove warmed up for 1hr with 15lbs of dry ash and oak. It's just barely making a flame. If I turned it down even a hair it would snuff it out and start making creo. This is doing well babysitting the tstat but it's still going to be above 75°F in here pretty soon. The other issue is loading < 10lbs where it may not be able to keep the draft going with the tstat reduced.
![[Hearth.com] BK Ashford 30 Install [Hearth.com] BK Ashford 30 Install](https://www.hearth.com/talk/data/attachments/242/242214-a3d067bc09c67c80231fdd8938db53af.jpg?hash=u-gdXcmp9i)
