BK Sirocco 25 Help Please
Two thoughts. To get more fuel into the stove, empty out ashes more frequently.
Second, that is a nice load of small pieces. As someone already suggested, that is a lot of surface area and will combust quickly.
Of course I have a KE40, but each piece is 12"+. Can you get some 12" rounds and split them in half. Then play tetris!
BKVP
Realistically how often should I been needing to empty ash out of it when running 24/7? Currently needing a clean out every 3-4 days and tons of ash in there.
Have half rounds in my racks. Next year’s order definitely will be ordering bigger round chunks. This wood was last years wood for an open face fireplace that was there until chimney went poof on us in dead winter.
Reactions: Burnin Since 1991
ash depends on the species. BKVP burns coniferous stuff with very little ash.
If you burn maple, you drown in ash. (reason I dislike maple...)
when I'm burning 24/7, most of the winter. I'm cleaning out every couple of days depending on the wood. I try to leave about a half inch after cleanout and go from there.
Reactions: inactivenow
I assume that you would need to run that load with the bypass open until the cat is hot, and then with the thermostat on high until it can be turned down to low.
Approximately how long for each phase? Do you look for all of the wood to be bricked (charred outside) before turning down the thermostat? Or it is more related to time and 'sensing' that there's enough heat in the wood and stove to reduce the air flow?
Yes run with bypass open stat all the way open until cat is in active range or if cat is already in active range (hot reload) let wood catch and char then close bypass.
Turn stat to 5:00 for a bit, then 4, then final setting for the load. I can’t really estimate a time. Lots of variables there.
Reactions: Quirke
I burn straight oak. Now got a great question about your comment about BKVP, always been told never burn pine and such as fire danger from massive amount of creosote? Whats the wisdom on this? I can get pine WAY cheaper than oak. Any insight on this would be great
PINE is FINE.
Hard to say. On cold starts I run with bypass open until flue temperature is approaching 8-900F, by which time the fire is well established and the cat thermometer approaching active zone (oftentimes it has not reached it yet, but the cat is still plenty hot to catch).
On hot starts basically the same, until I see that all splits have caught. That often coincides with the flue temperature.
On closing the bypass I immediately dial the thermostat down.
Reactions: Quirke
I would not burn with the bypass open until the wood is charred. Close it as soon as the cat is up to temp regardless of whether the wood is charred or not. On a reload with the cat still in the active zone, I keep the bypass open 2 minutes or so to exhaust the cooler air, and when you have some good flames (3 year old wood takes off before you can close the door), you will be hot enough not to shock the cat (I believe) when you close the bypass.
Pine is fine.
The myth likely originates in the following (is what I've read - take it fwiw).
In the old times, if your wood ran out in winter, you *needed* new fuel. Cutting down an oak would not work. It would not burn.
Cutting down a pine, you could burn it.
But because it's wet (not dried/seasoned), it would result in creosote. The pine was accused of being the cause of the creosote while the operator burning wet wood was the real culprit.
So, dry your pine/fir/spruce and you're good.
(And the nice thing is that in most climates, at least the one I have here on Long Island, pine dries to perfection in 1 year.)
So if you need to get ahead on your wood supply, get pine/fir/... and burn that next year, ALSO (at the same time), get some maple/cherry. That'll be good the year after (after 2 years drying, if split not in too big chunks). ALSO get oak. It'll be good the third year.
So once you get a lot of wood, and then after each winter you only need to replenish what you burned. That can then be oak or other woods - they'll be good to go as they will only be needed 3 years from then.
Bottomline: pine is fine.
I also have a King 40 belly of 9" in depth. We've burned since first of October and have not more than 3" in the bottom.
BKVP
BKVP
I cleaned all ash out completely Tuesday afternoon. Here is how much ash has built up since then. This was taken this morning. Again burning straight oak. Its almost already due for a clean out again.
  • [Hearth.com] BK Sirocco 25 Help Please
This is related to the wood, not the stove.
Some wood species make more ash than others. And within the same species it'll depend on where it grew, and e.g. whether bark was on the pieces or not.
If I burn straight red oak, I can go about a week and a half before (and this is important), I find there's too much ash in there. THe important part is "I find" - because it relates to my OCD of wanting the firebox to be as full with fuel as possible. Therefore I never let it fill the belly to the top of the brick.
Your insert may have a shallower belly (depth), leading to it filling up quicker - not sure.
But it's not the stove. Ashes are mostly noncombustible left-overs. No stove can burn (and thus make into exhaust gases) things that are not combustibe.
Completely normal for hardwoods. The higher the specific gravity of a species, more cooling properties. If you can, switch to softwood for a day or two and you'll see the difference.
BKVP
BKVP
So just normal pine would be fine for the softwood? Or recommendations on wood types? Im in New Hampshire so we have lots of options.
Reactions: stoveliker
Larch? Known as Tamarack out here...
BKVP
Reactions: GG Woody
When you accumulate excessive coaling from hardwoods or pushing the stove, the coal pile can be reduced quickly by tossing a couple smaller Pine/softwood/any smaller very dry splits on top.
Burn down the coal pile at a wide open or very high burn rate. Great heat output. Opens up your firebox for a full reload etc.
Worth playing with.
Takes some forethought/planning/time management.
Norway spruce is great in the BK’s I burn alot. Seasons quick, seems like no ash.
Reactions: BKVP
Calm down Robert (lol), stick with us here and we can get you into a comfortable operating window. I agree with all the above, but wanted to try and break it down for you to aid in your adventure. My setup is nearly identical to yours other than I have the PI29 insert, a 32' exterior chimney. I did install a damper in my insert along with a manometer, and honestly, I don't see much of a difference in operation.
1. Dry wood is imperative. You indicated yours is dry. Ash is a byproduct of the species, if it accumulates quickly, there is nothing you can do other than changing species. I can go 30 days before removing ash burning oak splits here in eastern PA. So let's move past that issue.
2. Smoke Spillage. That is a direct result of draft issues. With your height should not be a problem on reload but let us discuss. My reload process is to open bypass and wait about 5 min or more. Damper is fully open, tstat also fully open. Then I slowly open the door to allow the interior air in the box to equalize. I never get any rollback of smoke. At this point you should be down to hot coals, so there should not be much unburnt wood that creates smoke. Perhaps you are reloading too frequently. Stir coals with rake, reload, close door and let reload catch fire. After 10 min or so then close bypass and set tstat and fan.
3. Cat disengaging. This could be a function of your calibration of the cat thermostat. Do a search in this forum of calibration. Several excellent threads of how and where to set the thermostat. For 2 years mine was not calibrated and I would see it fall out of the active zone when in fact it did not. This led to more frequent reloads. Once I truly calibrated, I was able to get 13-14 hours easy. With the longer burn however, the temperature of the air coming out was lower. l learned to be satisfied with less "hot" air but a long steady stream of really warm air. The Sirocco will not give you 70k btu on high like some free standing stoves, just a performance factor. So perhaps lower your expectations (if that was indeed a consideration).
Please reply back, show photos, ask questions, you will not be judged. This is an amazing community of committed burners, and I am sure all want to see you settle into a satisfying and rewarding experience.
We're about 2 weeks into daily use of BK Ashford insert. I encountered some of the same issues and found this thread VERY helpful.
I have a follow-up question: for BK inserts, how much does fan speed affect burn time? I understand that the thermostat responds to heating demand, and so I expect that faster fan speed increases heat demand and reduces burn time. I'm still having issues with the cat stalling out on overnight burns.
For folks getting 10-12 hr burns, are you turning the fan off, low, or otherwise? Does it have a major effect, or should I be focused mainly on the air flow?
The above screenshot is from BK’s online owners manual Ashford Insert. When the CAT stalls where about is your thermostat dial? To my understanding any setting above the 2:30-3:00 o’clock(as shown) could/might/maybe cause the stove to stall.
I have a BK Princess freestanding stove, when I run a window fan behind the stove I get a higher burn rate. I’m pulling hot air away from the stove thus “fooling” the thermostat into thinking the room is colder than it really is.
Reactions: GG Woody
It should be noted (as posted numerous times) the combustor thermometer on certain units use a "switch" and others use a bimetallic spring. The AF25 & SC25 both have switch type of thermometer. Once the combustor hits 550F, the needle moves to the right, arond 12-1, referencing a clock. When the combustor drops below 550F, the needle move to the left. It is very simple and yet very confusing as most of our units have thermometers that fluctuate during the burn cycle.
Air movement across the stove top of those with the bimetallic, can influence the actual reading as air hits the bimetallic spring. That is why the manual instructs users to turn off the fans for 10 minutes or so to then take a reading.
BKVP
Thanks. I read previous posts talking about "switch" performance of BK thermostats and was wondering if that applied here (I also missed the part about fan and reading, thanks also for that).
I'm still having trouble reconciling that with what I see on my Ashford 25 insert, though. When I have a new load and I turn down thermostat, I get a good glow on the cat and the thermom sits at 12-1p as you describe (and no higher). As the burn progresses and less cat glow, the needle moves down to sit at the edge of the red zone for an extended time period. And when cold (or late burn/coals) it sits in grey zone (~10 o'clock). All of which is to say that I'm seeing it move between 3 distinct zones, whereas if it were a switch I would expect it to only be in 2 different positions. Am I missing something here?
BKVP
