BobMac said:See this is a used furnace ussc had problem or you could say factory defects.
Where excess sawdust was leaking from the auger shaft opening and landing on the hot exhaust blower housing which charred and turned to soot.
might want to try installing outside air and sealing all pipe joints
j-takeman said:BobMac said:See this is a used furnace ussc had problem or you could say factory defects.
Do you have any more info on the defects, Possible cures would also help?
Captainmt3, Do you have the furnace on a stat and does it spend a long time in the low setting?
kinsman stoves said:How about an appliance adapter? After looking at the pic I see it. Please disreguard
Not 100% on this but could being to close to the garage door be an issue?
Eric
Shortstuff said:I would extend that exhaust pipe vertically through your soffit, roof and then up high enough to be within code - perhaps 8 to 10 feet.
