Cherry vs The Winch Part 1
thewoodlands
17,990
In The Woods
Picture 100 0375 is the hung up Cherry and 100 0376 is the winch hook up I started with. 100 0378 is after I winched it against two trees, I thought that if I got that far it would come down(I was wrong). Picture 100 0377 is well how do I say this, up the hill down the hill and then the battery died. Back in the woods 1.5 miles best guess and going on 2:00 pm what do you do, waited about 20 minutes and the rhino started. Most smart people would call it a day(not me) lets winch down that cherry, battery goes dead again. This time it seems I'm in for a long walk, tried about 4 times and the rhino is saying walk, call the wife on the cell and explain things so I decide to try one more time (the rhino started) packed the gear and left for home. Winching 101 classes coming up.
The cherry did come down alot, will go back at it Saturday.
zap
  • [Hearth.com] Cherry vs The Winch Part 1
Keep the engine running when you're using the winch.
Maybe change the pulley to the cherry.
Wrap it on the cherry, tie one end of the winch rope to a tree, thru the pulley, other end to the winch, you'll get double the pull & easier on the battery
Sometimes helps when you need to pull at weird angles too.
From the pics you already know that.
Will be better wood since it's taking more effort to get it :)
It was running the whole time, thats how much of a drain it was. The battery seems fine at this moment. Quads I don't think the winch will run unless you have the rhino running.
zap
My 8000 lb winch gives the alternator on my tractor a run for its money when I run it for extended periods.
The direction I started winching the tree was wrong, if I positioned the rhino like I ended up the tree would be down. I need another tree saver,snatch block and d-shackle.(Off to Tractor Supply this week).
Zap
Zap
You just needed a reason to go to the TS store. :)
Shop around some, there is sure to be something else "you need" ;)
The most life I ever get out of my ATV batteries is about 2 years. The battery might be getting weak, but like you said, the winch was probably drawing that much.
Tractor Supply, one of my three favorite stores!
If you parallel another battery into the system, or series two six volt batteries together you won't have these issues.
I have a big locust tree that fell over in the crotch of a walnut tree, looks a lot like your situation, bigger trees, and a little less hill involved. Mostly I've just been looking at it saying, that is good wood, but not worth my life or limbs. But your winch set up gives me some ideas, I can stay far away and give it a shot. If it takes 4 hours to do this though, I could cut down and buck 4 elms, not as good of wood, but much easier to get to.
zap
zap
Mike be careful, I had one end on the ground to work with and was at a safe distance when winching.
Zap
you should really be using a snatch block to another tree #1 and second why dont you trypulling the tree down with the Rino rather than usign the winch? I ahve used those Rinos before, they are jsut a big, heavier more powerful atv.
Rhino would just do so much and then start spinning.
I used 2 different trees with the snatch block after I pulled it down without the snatch block
The winch with a snatch block with this tree was more powerful
My mistake was pulling it down instead out.
zap
I second the 2-6 volt golf cart batteries in series. You could also just keep a spare lawnmower type battery that's 12volt to restart the Rhino once you use all the battery.
gotchya..I was always told to use the snatch block, but dont put your winch cable through it, but rather no-stretch rope. I bought some logging rope in 5/8", 150' of it I beleive..About a buck a foot!
A DC winch motor draws allot of current.
It is not designed as a continuos duty motor.
Running it under load, for long periods of time will burn up the motor.
Be careful adding batteries to run the winch for long periods.
bull rope awesome stuff
You would be amazed what those little winches will do. HF will also sell you a no questions asked replacement or credit to upgrade 3 year warranty. I pulled out a bunch of ~24" diameter trees over a large embankment last winter. By the time I had skidded the tree and blocked it, the winch had cooled off and was ready to go. That said, once you use a Farmi, you are forever poisoned.
