Ashful
That clears it up. They say right there, 31.9 amps rating, max fuse size 40 amps. You’re already on the right track, excuse my tangent.
No sweat. I appreciate the interest.That clears it up. They say right there, 31.9 amps rating, max fuse size 40 amps. You’re already on the right track, excuse my tangent.
![[Hearth.com] Choosing the right brand for a mini-split [Hearth.com] Choosing the right brand for a mini-split](https://www.hearth.com/talk/data/attachments/227/227541-0f392e197071e8a072adb11a51a95ae9.jpg?hash=MtGM-OrQ-v)
I have four, ranging from 3 to 24 years old. None have ever been cleaned, nor to they look like there'd be anything to clean from them, so this is a surprise to me. Other than a little dirt in the bottom few inches of a 48 inch tall heat exchanger, mine don't seem to pick up any visible dirt.When I bought my townhome in CT years ago, I cleaned the condenser outside. About an inch of s*** came off it like a rug. I don't know if it had ever been cleaned.
Yeah. No doubt. I was at the mercy of many others when planning this project. Frankly, I don't think an installer could have gotten it done any quicker, being how my units arrived at the start of peak AC season. I was waiting for about 1 month to iron out the discounting that i would get with Mitsubishi. All said an done...I have a big smile on my face.Looking good but expect you are going to regret not having it on line during the upcoming heat wave![]()
However you have to access the front of the unit where the air first hits the heat exchanger. That is where you have to clean.I have four, ranging from 3 to 24 years old. None have ever been cleaned, nor to they look like there'd be anything to clean from them, so this is a surprise to me. Other than a little dirt in the bottom few inches of a 48 inch tall heat exchanger, mine don't seem to pick up any visible dirt.
But, you have me curious to give it a try. I assume you're removing the top grill, and spraying from inside toward outside, with a garden hose?
Power to the condenser is complete with 50A disconnect. It was cheaper then a 40A disconnect.
Unit is anchored with concrete anchors.
Next step is linesets and control/head unit power with 14/3 cable + the condensate line..which is easy.
The head units are two 120V hot, 1 ground and 1 low voltage communication wire.
There is a lot of confusion on what type of cable to use to power the head units. Many use shielded, 14/4 stranded, and a few others. The manual only specifies 14 guage. I called Mitsubishi technical support and the tech emphatically said "You will have no problems using 14/3 standard home romex..that is what you should use." Music to my ears as it will be quite cheaper. I asked about burial outdoor cable and he said that you can use that but it would be an overkill. I couldn't find any, so standard Romex it is.
That's great to know..thank you for the input. Most of the posts I saw about romex involved an old electrician throwing a fit for using romex outside.I have had four Mitsubishi mini split systems, three are at my current house, and all indoor units were wired with Romex. They were installed by three different installers at three different times, so seeing they all used the same makes me think that’s the standard way of doing them.
Two of them made special mention of the condensate line. Namely, it should be very highly sloped, as they have had a lot of problems with condensate lines backing up on these.
You know, I hate to admit this, but I was wrong. I know they ran Romex to the indoor units at my old house, but there was a junction box between. I just got home and checked each of the outdoor units on my current house, and they are all multiconductor THHN/THWN with black UV-rated jacket. Sorry for posting bad info above, I will go edit that out.That's great to know..thank you for the input. Most of the posts I saw about romex involved an old electrician throwing a fit for using romex outside.
Yup..I have at least a 15° pitch from inside to outside with my condensate tube. Thanks for the heads up.
Do you mean UV-resistant cable, fbelec? There is a UV-resistant Romex variant, usually colored gray or silver.my last code update class had a guy come in and said that the only wire legal to use is a special uf cable that is stranded wire.
my last code update class had a guy come in and said that the only wire legal to use is a special uf cable that is stranded wire. as of late i have changed the cable that is run in the slim duct or liquid tight for different brands between the units that are 120 or 240 volt indoor unit's to uf. anything that goes outside has to be uf cable even in pipes. uf or thhn. it's funny the last unit don't remember if it was a mitsu or daikin it had to be run from compressor to the indoor unit a 6 wire that was shielded. they wanted the shield because the didn't want interference in the units talking to the compressor. low voltage motor
That is awfully strange about the shielding needed for interference. In the automation world, low voltage (12-24) is run very close to high voltage. Most of the time, most is unshielded.
If there was a large interference issue between unit communication, they wouldn't put the terminal blocks right next to each other.
Quite frankly..no one will know what wire I used. It will be safe. It will be per manufacturer's recommendation. I can sleep well.
Ordered some cleaner yesterday. Looks like I will be tackling our system's cleaning soon.Here's a related/unrelated head's up. Went to clean the filters on my Panasonic mini-split with a fresh, curious eye, so to speak. I'm talking about the indoor part. This unit is from 2010.
Holy crap, there seems to be an entire ecosystem come to life on the scroll fan and drain tray. I'm calling a professional to get both of them out of there and clean it. Sheesh! Frightening.
It's clearly my responsibility to dig into this stuff and learn all about it, but it's a tough assignment to figure out what you don't know.
