Cord Estimate
RDabate
91
Ellington, CT
I'm only on my second year of burning, and I'm horrible at estimating how much a cord its. Do any of you have an estimate on how much wood can fit in the back of a 6 1/2 Ft Bed of a pick up?
I have a 2007 Toyota Tundra w/ 6 1/2 foot bed. I stacked exactly 1/2 cord of cut and split wood and then put it in my bed. I barely got it all in. It was mounded quite high in the middle and really weighted down, so I would say 1/2 cord max for a 6 1/2 foot bed.
I would concur.
It's easier to get 1/3 cord in a short bed than 1/2 cord. But it can be done.
If you stack the wood flush with the bed it's .45 cord
If you stack 6" above the bed rails it's .6 cord
These #'s assume your bed is 6' wide (mine is) and 18" deep (like my truck)
Next time you have a pickup full, unload it into a stack only one split wide, 'face cord' style. Then measure the front dimensions of the stack (e.g. is it 5 ft long by 3 ft high?), and multiply by the length of a split (convert inches to feet) and you'll actually know how much fits. Then post it here. I think we get a lot more guesses than actual measurements. Before you post the answer, post a picture of the wood in the truck and we can have a contest to guess the amount. Put me down for 0.42 cords, even before I see the picture.
I wouldn't buy cords from you guys then. Either that or I won't buy used trucks from you.
For those of you that cannot read a measure tape and convert to cu ft, maybe you can estimate the weight of your load. Here is a chart of firewood and weight.
(broken link removed to http://www.consumerenergycenter.org/home/heating_cooling/firewood.html)
So if he was collecting maple (taking a middle of the road weight for green maple) at 4390 per cord - 1/2 of a cord is 2195 pounds evenly distributed in the bed of a truck, there is a problem? Dunno, maybe my truck is a manly man truck or something, but it pretty much laughs at 2000 pounds evenly distributed in the bed. That is actually just about the right weight to level the truck out instead of its normal butt up stance.
You would really hate to see how I load my trailer.
That was green White Oak.
  • [Hearth.com] Cord Estimate
I load the same way its only going to take so much weight why stack
That doesn't look like White Oak to me - maybe Mossycup Oak /Bur Oak, but I guess that wasn't your point. So how many cords in the trailer?
Follow this link and scroll down about 1/2 way (broken link removed)
Pretty good idea of what will fit in a truck.
I tried to copy the pics into my post, but I didn' work the way I thought it would.
General consensus is a standard sized bed will hold 1/3 of a cord loose stacked wood.
Gar-own-double-teed White Oak. A little over one, by my guess. I don't stack until it gets staged for winter burning (in an old wash house next to the house) so I rarely get a measurement of any load.
Want to hear something pretty amazing? If you look at the size of some of the rounds on the bottom, they get pretty big right? Yeah, that was only one section that split from the tree. The trunk is still standing and supporting the rest of the tree. It was (is) a big sucker.
EDIT: Whoops, sorry for the unintended hijack. :red:
Here we go. With pictures
Small Pickup -- 1/4 ton
(broken image removed)
With or without racks this truck bed holds approximately 1/2 (one-half) cord of wood. One load ticket required.
Short Bed Pickup -- 1/2 ton
Long Bed Pickup -- 1/2 or 3/4 ton
Without racks this truck bed holds approximately 1/2 (one-half) cord of wood. One load ticket required.
With racks this truck bed holds approximately 1 (one) cord of wood. Two load tickets required.
Standard Truck -- 1 ton
With high racks this truck bed holds approximately 1 1/2 (one and a half) cords of wood. Three load tickets required.
How much weight your truck can carry is for you to figure out.
Chevy Silverado, 6.5' bed - exactly .43cords, lightly mounded in the middle, even with the sides. .42 to .45 is my estimate. Put a bag of kindling in the passenger seat, and call it 1/2 a cord load.
Without racks this truck bed holds approximately 1/2 (one-half) cord of wood. One load ticket required...
How is it that three different sizes of pickup can all carry 1/2 cord? The answer is that document is meant only to determine the issuance of a load ticket. They don't care if YOU get your money's worth.
I figure a small truck and a shortbed 1/2 ton would be about the same size. A full size long bed should be a little more though. I saw something like this somewhere else on the net that was a little better than this one. I'll keep on looking.
I'll just take the things given already . . .
6.5' long X 6' wide(I doubt that is quite accurate) = 39[]
Cord = 128 cuFt
1/2 X 128 / 39 = 1.64
At 20" deep, a truck bed 6' X 6.5 would hold 1/2 cord
Change the width to 4' and the stacking height required for 1/2 cord becomes 30"
It becomes obvious that, for those of us that burn 8 cord -or more- certing home wood in a 6.5' pickup is not the best way to go.
I stand by my statement that though it's possible to get 1/2 cord in a 6.5' pickup, it's more likely to get 1/3 cord. :coolsmirk:
