For quite awhile, I was having trouble with my Auger Motor speeds, due to having incorrect motors. Finally got it swapped out & the stove was running like a CHARM for a solid month.
Somewhere along the line, it started running hot again. This happened following a routine shutdown & cleaning. I adjusted by bottom settings from 3-4-1, down to 2-4-1... figuring I could at least slow the speed. That seemed to work & I was happy with the outcome. Had a little cold snap, below freezing a few days in a row. Worked like a charm, had my settings on 3/5 & 4/6 - all seemed appropriate given the weather. Warmed up, back to 1/3... again - all with main settings at 2-4-1.
On Monday 12/7 overnight into Tuesday (beginning of cold snap), I actually timed it out... on 3/5, the stove went 12.5 hours on a full hopper. I was pleased with that. Shut it down Tuesday late morning to clean, started it back up, finished out the cold snap & shut it down again Thursday late morning for another cleaning (working from home makes it so much more convenient). Started it back up... it seemed okay. It was cool out, but I had it on a 1 & 3 setting. I went to bed early Thursday night, and Friday morning I had to leave for work at 4am. I would say the hopper was about half empty when I filled it around 3:45am. I didn't think too much of it. Filled it & went into the office today. I got home around 3:30, and the tiny square in the bottom of the hopper was all that was left with pellets & it was out by 4pm. So today, on a 1 & 3, the pellets only lasted about 12.5 hours... the same as earlier in the week when it ran at a 3/5. That doesn't seem right??? Cleaned it, started it back up & I could just see the stove PUSHING.OUT.PELLETS. during warm up. I dropped the feed to 1, making it 1-4-1... and the stove set at 1/3 still. I'm gonna go bump it back up to 2 now that it's started (I didn't want it to over feed & put the flame out before starting up) to see how it looks, but I'm concerned.
Any thoughts on this? I'm beginning to think it could be the control board. The stove is heading into it's 10th year of use & the control board is original. I really don't think it's the auger motor acting up because.. I had it working after all my issues. And, adjusting the feed to 2 (2-4-1) really made a difference.... short term (like 2 weeks'ish).
Any insight, as always, is appreciated.
*NOTE: I do want to check to see if I'm running in the correct mode, in case something reset on me... but I totally forgot to do that before startup. So I'll hit that with the next shutdown/cleanup/restart.
![[Hearth.com] Could it be the Control Board? Inconsistencies in Pellet Feed on Englander 25PDVC-55SHP10 [Hearth.com] Could it be the Control Board? Inconsistencies in Pellet Feed on Englander 25PDVC-55SHP10](https://www.hearth.com/talk/data/attachments/270/270489-0a259bb758d795ad23f0c887ba37425d.jpg?hash=B37NxBxC5f)
![[Hearth.com] Could it be the Control Board? Inconsistencies in Pellet Feed on Englander 25PDVC-55SHP10 [Hearth.com] Could it be the Control Board? Inconsistencies in Pellet Feed on Englander 25PDVC-55SHP10](https://www.hearth.com/talk/data/attachments/270/270491-9fa88ade4ae8f51faa5b05270367b7b3.jpg?hash=rgBqnLSftE)
![[Hearth.com] Could it be the Control Board? Inconsistencies in Pellet Feed on Englander 25PDVC-55SHP10 [Hearth.com] Could it be the Control Board? Inconsistencies in Pellet Feed on Englander 25PDVC-55SHP10](https://www.hearth.com/talk/data/attachments/270/270853-ba806fd64d59da363c6a8e4882e1db28.jpg?hash=WLDHgAipWE)
