maple1
This has to be a troll post right?
I've been wondering that since the first post I saw...
No I really don't think so. Sadly this is really far from the worst I have seen. He is atleast making an attempt at safety even if he is doing it half assedI've been wondering that since the first post I saw...
If it is either of them (which is the only 3" that would be at a hardware store) it is not made to contain exhaust from a wood stove. Pellet vent might hold up but not offer proper protection. B vent could melt. Pipe is not pipe. You clearly spent quite a bit on the solar setup in this shed but refuse to spend much of anything to keep from burning it down. And Batts of insulation leaned up against the wall is not proper protection.I didn’t even know there was a pellet vent of b cent stove pipe? I thought pipes are pipes but hopefully the one I got is made for a wood fire. I’ll send pics soon.
Everybody makes fun of my safety features but in reality behind all the insulation and my triple wall pipe going through the wall my shed walls are pretty much cold to the touch. I know it’s not to code but for a fire for just a hour or two it’s perfect.
No it is not common. And insulated chimney pipe still needs 2" clearance to combustibles.Triple walled insulated with RockwoolCommon.
![[Hearth.com] Duct work for double walled pipe? [Hearth.com] Duct work for double walled pipe?](https://www.hearth.com/talk/data/attachments/254/254666-8e9d296a63b2b8ddd4843c81babb3054.jpg?hash=bplSE-3au3)
How do you get rid of it? A proper chimney and dry wood. Yes it is bad that stuff will cause a chimney fire which your setup won't be able to handle. It may keep things cool when the pipe is 4 or 5 hundred degrees. But 2000 degrees is a totally different ball gameIs that what that is? How do I get rid of that? I was wondering why that was there. I’m burning wet wood with some dry. Is that black stuff bad?
It isn't a chimney. It is just in insulated pipeWhat’s wrong with my chimney?
Where are you measuring tempsThe fire temp should be around 400-500 I usually keep it around 600 I’ll start closing vents when it get higher. I’ll start only burning dry wood as long as I have it.
