Hello,
I live at 4,000' in north central WA right on the U.S./CA border. Winters are long and harsh here, and a woodstove in the shop is a must. My shop is 36X48 with a peak 20' from the slab (inside). The stove sits in the middle of the shop with the pipe exiting 3' away from the ridge. I have an older (pre epa) large woodstove (8") with an inside box of 16" X 24" lined with fire brick and stainless steel panels. I did the install last year and used new 4 each 48" X 8" Durablack single wall pipes up to the slip/box. The pipe is already failing on the female/receiver ends where the male ends sits/stops. I've never had inside pipe fail before it was at least 10 years old (over 40 years of 7 chords each year). I've also never had an inside pipe run this long/high, so I'm guessing this has something to do with it. I burn mostly Doug Fir that is split and dry, occasionally a small amount of aspen or oak also split and dry. Draft seems fine with no inside smoking and is easy to light.
Question:
What are my options?
Thanks
Question:
Thanks
