Fire Damper Deal
mellow
Resident Stove Connoisseur
5,864
Salisbury, MD
Came across this deal on Grainger this morning, I ordered 1 and thought many some others could take advantage of it.
https://www.grainger.com/search?searchQuery=3zw32
$10 for a 165::F fuselink fire damper is a deal.
I will be using this to blow cold air down from an upstairs room to the room my insert is in through the ceiling. I will get a computer fan and put it on top of this so it should be pretty quiet.
Hope this helps you guys get compliant with fire codes and be safe.
I wonder if it matters or not that this unit is meant for being installed in duct work,,,, not sure if it would be kosher to use it in a means it wasn't designed for?
