Few installers seem to want to do a block off plate, just how it is. Insulation though is mandatory IMO. My installer wanted to use the pink stuff and only on top (by the cap). I got them to do top and bottom although they did not do the bottom to my satisfaction and I ended up doing it again.
If this is supplemental heat insulate and make sure you're getting the most out of it through proper operation. There is a definite learning curve to get good heat. If you're convinced you need more, upgrade. I have the 550 and I'm happy but I needed a flush mount unit. The Kennebec 450 is very capable and extends (adjustably) onto the hearth. Therefore heats a little better for it's size and depends less on the fans which is especially useful during power outages. Do a search on that unit here and see what you think. From what I have read there is not a big drop off in performance despite the manufacturers quoted spec's.
