I've cut literally 40+ cords of blow-down from super-storm Sandy, almost all stuff 2x - 3x larger than this. Going top-down always sounds good on paper, but it's not really practical. I'd be doing it exactly as Jags describes.Double blow-down! Wow. Is it hung up in other trees? If not, I'd probably start taking material off the tops of both trees working down toward the roots. Clearing limbs first then bucking the trunk in 5' sections. If it wants to go back to vertical you'll start to see that gradually as you work toward your way to the base. Also, you'll be working clear of most of the reach of the trees should any movement be a concern .
ThanksNice work and beautiful woods - jealous of the hardwood and wish we had some around here. Glad you got that done safely - had to be a little bit of pucker factor because that is a lot of weight!
No, I don't think I noticed any moths. The only things flying around were wood chips from my saw.Are those white (female) gypsy moths on the base of the tree trunk on the left ?
I am with you. I would work it from the top of the tree back to the base. My log lengths I cut to are 18". So I would start on the bottom one, take 18" off then take 18" off the top one, then 18" off the bottom and alternate back and forth a little at a time occasionally turning my saw off and setting it down to see if I would feel the trunk and when equilibrium is being approached and if it was about to snap back up. Just stand clear as you cut in case it does snap back. Err on the side of caution because this has the potential to cause nasty injuries. Take your time, think it through and don't rush. I am not a professional but that's what I would do.Bottom first . . . and I would personally work it slowly from the top . . . since there is a chance that as weight is removed from the bottom tree being cut that the top tree and root ball could slowly (or quickly) pop back up to the "standing tree position" (new yoga position). As mentioned, cutting the bottom tree would also get everything out of the way so no hang ups.
In any case, just be very careful . . . plan your work . . . keep stepping back to analyze everything and be prepared for movement.
Slow. You really notice whey it starts to stand up. Plenty of time to step away.
That is why starting from the crown down is the safest in my opinion. I consider myself a rooky in this field, always will be since I cut maybe three to four trees a year.
View attachment 182039 View attachment 182040 View attachment 182041
And some more pics
View attachment 182042 Started limbing
View attachment 182043 And cutting. Rooky mistake! A pinch on a first cut
View attachment 182047 View attachment 182049
View attachment 182051 View attachment 182052
The crown was held up on the bottom branches and the uphill. Eventually the cut sections dropped and I started working my way down, both trunks
View attachment 182054 I was worried about this sapling a bit
View attachment 182055 Five minutes later....
Fun workout! Now you're way ahead (plenty of time to drag it out out/split and stack)! At least you have some shade in there. I loathe collecting firewood when it's hot and humid out. Where you live it must have been a nice brisk workout.![]()
