1) The auger motor quit running. I tested the motor its fine. I jumped the vacuum switch, fine, tested snap disk #2, fine, replaced anyhow so I decided it was the control box. I replaced that still no auger.If I put the control box to test mode everything tests fine, both fans, auger motor and igniter. I put a multi meter on the wires that go to the auger motor and I’m getting low voltage to the motor 8.9 volts. During test mode I get 120v.
After putting in the new control box, I still don't have function of the auger motor and the convection motor will not shut off fan runs continuously 24 hours when the stove is hot or cold @ 1.05 volts. As soon as stove is plugged in the convection motor starts and exhaust blower both run. Tested thermo coupler, fine. Checked connectors.
Help needed, tried everything we can think of so far.
As always, unplug when working in the cabinet ...
