![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196459-58fe47390a8a89ac107bf70ac53824c7.jpg?hash=DBCtZvy0qX)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196460-8732e4a11cd8073823fee92a456b8fb3.jpg?hash=nDjCYloLze)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196461-669c8e763e2bd9ea2cb2cb6b2926347b.jpg?hash=nDjCYloLze)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196462-40e2de8ee9383c1675bb6de0527a3c0c.jpg?hash=JsNalSVRhM)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196463-a7694f2a9dfa3f64b53580d613aeebb7.jpg?hash=ssr-nP80P0)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196464-32c453a271b9f72e0be668261a534408.jpg?hash=NSISImhRzK)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196465-0d4652d782a092415f27f68b7fdc4995.jpg?hash=J4LJKiMk8n)
Thanks for the detailed progress pictures. Wondering about the hot air ducting from the fireplace. Is this with the remote heat transfer kit with blower in the lower vent? Will there be another vent taken off the right side of the fireplace so that there is at least one gravity fed vent? the reason I ask is about how the heat is vented in the event of a power failure.
Is the flex ducting type B vent? Is there a firestop as it passes through the floors? The framing obscures the side view. Is there a convection air intake in place?
Thanks, that's good. I haven't been able to locate the remote kit manual, thus the questions. The vent on the lower right side sounds like the intake. Hard to see in the pics due to the angle and location. I still wonder about having a convection heat dump for when the power goes out, even if it is closed during normal operation.
Personally I don't know. A generator might help, if someone is home that knows how to run it. I'd check with PE tech support for peace of mind. You could try a pm to @thechimneysweep too.Ok I see what you mean about a convection heat dump. I could've added it but there is nothing in the manual stating it is required. My installer is very knowledgeable about these things and I'm sure would have definitely added it if required. He's done everything to code.
I do have a generator so if I sense it would be an issue during an extended power outage I can add the blowers circuit to the generator sub panel.
I am not sure what you are asking these questions for exactly? I think I sense concern in your questions? Are you wondering about a power failure that the duct will get too hot without the fan running? I am wondering what the difference would be in the fan not running and the gravity vent your asking about? Not trying to be smart, just trying to get smarter. I think you may be remembering the requirements for the older model. The new model 2015 only requires the 30sq. In IF a R.H.D. Is installed.Personally I don't know. A generator might help, if someone is home that knows how to run it. I'd check with PE tech support for peace of mind. You could try a pm to @thechimneysweep too.
Yes the concern is heat buildup and safety. The manual requires at least one gravity vent and a lower supply air connected to the fireplace. This is to prevent excessive heat build up. In the OP's setup there is no heat dump for the system if the vent loop running to the basement has no power.I am not sure what you are asking these questions for exactly? I think I sense concern in your questions? Are you wondering about a power failure that the duct will get too hot without the fan running? I am wondering what the difference would be in the fan not running and the gravity vent your asking about? Not trying to be smart, just trying to get smarter.
I just glanced over the manual.....I do not see that. I only see that if you add the remote h.d. You must have a 30 sq in supply air intake to the chase. No where in the current manual that I can see that there is a requirement for a gravity heat dump or Grill of any nature. I could be wrong, but hardly everYes the concern is heat buildup and safety. The manual requires at least one gravity vent and a lower supply air connected to the fireplace. This is to prevent excessive heat build up. In the OP's setup there is no heat dump for the system if the vent loop running to the basement has no power.
Saydinilli, does the remote heat duct need supply air? If so does it say that it needs to be in the actual fireplace? Could you actually duct the supply air from a bedroom or basement? As you can tell I have not yet read the manual in my research.
Thought that was odd, but now I think I see the difference. The original FP30 has this caveat on page 20:
IN U.S.A., A MINIMUM OF ONE REMOTE GRAVITY HEAT DUCT KIT MUST BE INSTALLED WITH THE FP30.
I just downloaded the FP30B fireplace manual. The remote vent section has been rewritten and the caveat has been removed.
Let's hear some of your thoughts....im interested. Do you think there is merit in drawing the air from another room vs from the stove room? I would like to get as much air circulating as possible. My new home build will be very tight with little air infiltration. What sort of things would you try to incorporate?Oh to have the forethought to have engineered integrating my new FP30 into my recently finished basement. No way to retrofit it, without serious investment due to the robust soundproofing efforts in the lower level. Major fail on my part, as the new wood burner has more then enough BTU output to warm the lower level and would do a far better job than trying to circulate air with the furnace. I'm sure there would have been a substantial trade off from the near bomb proof results I have now, sound wise, but the need for that is less often than the need for heat 4 months or more out of the year.
Yes, looks like they made some more notable changes. Your install looks top notch. My suggestion was just for improving safety but apparently this no longer a priority with the second generation of the fireplace.I read on PE's website somewhere I believe, that design changes were made on the FP30.
Glad we sorted it out for sure. I don't see any harm in adding the gravity dump though. Heat build up in the chase is the reason I added a second vent at the top of the chase near the ceiling to allow hot air to escape.
I'll post a pic if it later on.
What is the round outlet for on the front wall face about 5ft above the fireplace?
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196506-29f0835e6f976472f1e75e582be71960.jpg?hash=nDu27RShlX)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196507-b7ffbbc38efa705ffd3090965eb8b6c1.jpg?hash=77rq78P8CI)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196508-efcdf80a34639289be6e18c00a03d9d9.jpg?hash=cucqgS04X7)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196509-aa60dda71894a5b739037cb7c477becd.jpg?hash=lmhFl_75D3)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196510-376584cb0e0a4341ab904595afde13b5.jpg?hash=lWBmTphoHg)
![[Hearth.com] New Pacific Energy FP30 Installation Progress Thread [Hearth.com] New Pacific Energy FP30 Installation Progress Thread](https://www.hearth.com/talk/data/attachments/196/196511-3bc0f083300beb1061977359b971598d.jpg?hash=FH54JLUELM)
We have 2 gravity ducts on our FP30 (model A). I think if we ever had a power outage with a full load of wood things would get interesting real quick. I am absolutely shocked at how hot the air is that comes out of the gravity vents with the fan turned off. Our vents look like they just have normal dry wall around them. Normally with this unit I burn smaller fires, or really big wood one log at a time. When I want to run full loads all day long I use the 30NC in my basement.
That's why having a heat dump made sense to me, but maybe this is no longer an issue. Is there a convection outlet slot above the door on your fireplace? If so that should vent a lot of the heat.
