Should be fineWelp shes been takin apart and put back together again, i added a 12” section going outside so its a little farther away from my outside wall. Its now 2 foot of horizontal piping plus the exhaust, i looked in the manual and everything seems legit. Can anyone approve that a two foot horizontal section is ok,
I do not see why you added more to outside,but it will keep wall cleaner.You should be well under the max evl.A inside and outside picture(s) might help.Welp shes been takin apart and put back together again, i added a 12” section going outside so its a little farther away from my outside wall. Its now 2 foot of horizontal piping plus the exhaust, i looked in the manual and everything seems legit. Can anyone approve that a two foot horizontal section is ok,
Nobody would take back the vent so I decided to use it to keep my bricks clean, my buddy has a lot of black shyt on his walls so I wanted to avoid that. My camera took a dump so I cant take pics this min, its vertical 5 foot up to an elbow and two feet plus exhaust tip outI do not see why you added more to outside,but it will keep wall cleaner.You should be well under the max evl.A inside and outside picture(s) might help.
Yea pretty much with these stoves. For some reason they run cooler on one side . If your chilly turn it up, I had to turn mine up this morning to 6-7Morning folks! Its 17 here right now and im chilly as can be. Anyway my stove is letting off good heat on one side while the other side is cool at best. Is this normal operation? Im at 2-9 and the bottom three is 5-4-1..
