Hello,
I have had my P68 at least 12 years now and having a problem that I cant seem to figure out. We came home and turned on the stove and there was no power at all to the stove. Found a bad fuse on the circuit board. Replaced fuse and stove came on fine but would not auto ignite. Checked ignitor and it looked pretty bad and when taking out one of the wires fell off. Possibly the cause of the bad fuse maybe. Ordered new genuine ignitors. Was able to run stove by manually lighting and stove worked normal until we got new ignitors delivered.
Replaced ignitor and still wouldnt start. Cleaned everything real good and checked the fresh air kit and that all checked out good. Stove will time out and give me the 5 blinks of status lights. Ignitor light is on but after running a while I do not feel any warmth in the burn pot like the ignitor is not actually working.
Ordered an OHM meter and waiting for it to get delivered.
Same pellets I have burned all year
Door gaskets look good
I did order 2 ignitors so tomorrow I may swap the one I just put in with the other but suspect the first one is ok.
With having the original problem of the bad fuse what are the chances of the board being possibly bad? Everything works fine though when lit manually. Possibly the board isnt sending good voltage to the ignitor.
What is the voltage I should see going to the ignitor?
Thanks and appreciate any suggestions.
![[Hearth.com] P68 help [Hearth.com] P68 help](https://www.hearth.com/talk/data/attachments/311/311159-981fdafd3c701148b27b9304f01c4168.jpg?hash=ayAMQt4T3L)
