Understanding that burn time is always relative to the heat loss of the house. Burn time at 40º is going to be much better than at 10º. When the fireplace is being pushed for heat, the burn time could drop to 4 hrs.
Understood thanksUnderstanding that burn time is always relative to the heat loss of the house. Burn time at 40º is going to be much better than at 10º. When the fireplace is being pushed for heat, the burn time could drop to 4 hrs.
Yah i am so happy i randomly came across PE's line of zero clearance units. And you mean call around to find used fp30s in good condition?It's good that you are taking the time to explore options. Call around to local dealers too. Maybe someone has an FP30 they are trying to move.
Suggested in posting #2.Yah i am so happy i randomly came across PE's line of zero clearance units.
Its to late. Dropping off the summit and bringing home a fp16 tommorow. Just need class a chimney and chimney accessoriesUsed or perhaps a new one that a customer backed out on. It never hurts to ask.
Its going to work perfect in my size home! Thanks for your concern thoughFP16 is 1.6 sf firebox. Way too small
For a lt of the time it will be ok. When it gets extra cold outside it can act as a supplement to the primary heating system.Enjoy your new ZC fireplace! I think you're going to be running it hot and hard to provide enough heat for a house the size of yours, but at least that should ensure you're burning clean.
My home is not big by any means. If i had a 3000 sqft home i would agree with youEnjoy your new ZC fireplace! I think you're going to be running it hot and hard to provide enough heat for a house the size of yours, but at least that should ensure you're burning clean.
These pacific energy products are built for canadian winters , my pennsylvania winter has nothing on canadasFor a lt of the time it will be ok. When it gets extra cold outside it can act as a supplement to the primary heating system.
They are built in Duncan, British Colombia which has a maritime pacific climate. It's pretty mild.These pacific energy products are built for canadian winters , my pennsylvania winter has nothing on canadas
Glad you think so. Have fun loading it every 4 hours or so. Hope you have patience to burn the coals down and run the main house heater while that is going on. Can't say you weren't warned.Its going to work perfect in my size home! Thanks for your concern though
Like i said i appreciate your concern. Stay gladGlad you think so. Have fun loading it every 4 hours or so. Hope you have patience to burn the coals down and run the main house heater while that is going on. Can't say you weren't warned.
Thanks begreen without you and this forum i dont want to think about what wouldve happen had i installed that insert. And once it gets colder i will certainly post a pic.. its near 50 degrees right nowThanks for the update. I'm so glad this is working out well for you. It sounds like the house is tight and nicely insulated. Your wife will appreciate the extra heat when real winter settles in. If you get a chance, post a beauty picture with it burning.
