Has anybody had a chance to run one of these "smart" stoves with a thermostat yet? They are claiming 20 and 40 hour max burn times. http://www.quadrafire.com/
I'm thinking longer, even though it's not a cat.With it being a 4.5 cu ft stove and a good wood load in it a cat stove, you could get hour burn if everything is right.
With it being a 4.5 cu ft stove and a good wood load in it a cat stove, you could get 40 hour burn if everything is right.
Basically that means at 40 hours you have enough coals to start another load of wood with the help of firestarters.
Agreed - If it looked like their Explorer model I would jump at it too.If it wasn't a dang pedestal there would probably be one in my living room right now. (the 3 model).
You should be able to fab up some legs. With those and the satin nickel hinge pins, you'd be stylin'!If it wasn't a dang pedestal there would probably be one in my living room right now.
I just did my first burn. So far so good. Seems very simple and this really puts out some heat! I just ran across this thread so I will try to answer questions and keep you guys posted.Has anybody had a chance to run one of these "smart" stoves with a thermostat yet? They are claiming 20 and 40 hour max burn times. http://www.quadrafire.com/
It perormed great! The thermostat does all the work for you. You just set it and go! I did play with the temp and went from 90 to 8t then to 65 and back to 80. It did heat all 1800 sq feet of my home. It was 55 last night which was good because I was able to keep all the windows open. It did have a smell at first which I knew going into the first burn. Glass stayed clean but when I went to sleep and woke up glass was dirty. The burn time was just under 20 but I could have added more wood. When I checked on the stove after I woke up all that was left was hot ash. Im sure im going to really like this stove. It definitely outperformed my old insert in my last fireplace.Can you give us a summary of how it performs? Thanks.
Thanks for the update! Instead of going for the long burn I'd run the stove hotter for the next burn in order to bake in the paint. Try to get it over 500º and open up the windows.It perormed great! The thermostat does all the work for you. You just set it and go! I did play with the temp and went from 90 to 8t then to 65 and back to 80. It did heat all 1800 sq feet of my home. It was 55 last night which was good because I was able to keep all the windows open. It did have a smell at first which I knew going into the first burn. Glass stayed clean but when I went to sleep and woke up glass was dirty. The burn time was just under 20 but I could have added more wood. When I checked on the stove after I woke up all that was left was hot ash. Im sure im going to really like this stove. It definitely outperformed my old insert in my last fireplace.
